new pontoon owner in ohio
recently purchased a 1993 24' sweetwater pontoon without a motor. also recently bought a 1988 bass boat with a dt150 Suzuki motor. already got the dt150 mounted on the pontoon and in the process of getting everything hooked up. pretty sure I'm going to run out of time before the snow flies. sure I will be needing some help and advise on this adventure. thx, chris
1993 24' SWEETWATER
Suzuki 150 HP
Suzuki 150 HP
Re: new pontoon owner in ohio
Welcome aboard cds. Location? I'm in Elyria (about 30 miles west of Cleveland)
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
Welcome to the club.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Ted & Emily
2019 Yamaha 150 HP
Cds... welcome to the group...
If the Suzuki is a 4 stroke motor, you might want to ask around for setup advice prior to buying the new propeller.
Many Suzuki outboards have a planetary gear in the drive shaft, and they have a much lower gear ratio--slow moving prop. They require a large diameter, very high pitch prop.
Many marine mechanics can setup a Merc/Yammie 4 stroke motor on pontoons/tritoons. But Suzuki's are different animals.
[quote="Bamaman"]If the Suzuki is a 4 stroke motor, you might want to ask around for setup advice prior to buying the new propeller.
Many marine mechanics can setup a Merc/Yammie 4 stroke motor on pontoons/tritoons. But Suzuki's are different animals.[/quote]
No, its a 2 stroke motor. I just bought a new prop, 14" diameter with a 13 pitch. hopefully it works out, if not it will be a good spare. I'm looking to sell the prop that came on it, its a Suzuki stainless steel 14 1/4" diameter with a 24" pitch. what do you guys think I can get out of it?
1993 24' SWEETWATER
Suzuki 150 HP
Suzuki 150 HP
