keeping battery charged with high powered stereo?
I just ordered 4 JBL 6x9's to be powered by a pioneer 250 watt amp. the stock 6.5's are being replaced with good JBL 6.5's. I am mounting the 6x9's under each satee(couch) and should sound pretty good.
IF i dont get enough bass for a clear sound im adding a sub and replacing the 250 watt with a 4 channel 1000 watt amp.
My question stands, im adding a second deep cycle battery on a switch to make sure I always have a battery to crank. What are other steps to take to make sure i keep a charge?
- BassFrequency
Re: keeping battery charged with high powered stereo?
add one of theseAint Skeered wrote:What are other steps to take to make sure i keep a charge?
60HP Evinrude
60HP Evinrude
thats a big ass battery.BassFrequency wrote:add one of theseAint Skeered wrote:What are other steps to take to make sure i keep a charge?
How do the satee's work for speaker box's? mine are the plastic lower enclosures for my seats, might have to surround with life jackets to help the sound.
- BassFrequency
eh, they work but mine dont really have a good way to seal em. so any openings between the seats kinda become ports. I run so much power to them it seems to compensate for the excesive audio leaksAint Skeered wrote:thats a big ass battery.BassFrequency wrote:add one of theseAint Skeered wrote:What are other steps to take to make sure i keep a charge?
60HP Evinrude
60HP Evinrude
You don't crank with a deep cell, that's what starting batteries are for, deep draw batteries are made to play the tunes and run the TM.
Hmm, 1000 watts @ 13.8 Volts is around 72.5 amps an hour of draw
or 12 volts is around 83.3 amps per hour. You need a huge battery or multiple batteries
parelled to provide the current requirements. Keep in mind, that you will need short cable runs to the battery(s) and 0 gauge or larger cables. Big $$$$ to do it correctly!!
Creating an enviroment for speakers is challenging in a car. Add in a boat which has so much wood material for dampening and it gets even more challenging. A pre-packaged sub woofer w/ it's own enclosure might be the way to go. I would fire up the 6X9's and decide if it is giving you the frequency response you need.
2010 Harris Grand Mariner (May arrival)
22', tri-toon, 115hp Merc
Toonin' down the CT River
- BassFrequency
CT Arrow wrote:Hmm, 1000 watts @ 13.8 Volts is around 72.5 amps an hour of draw
try 316-500 amps/hour 6400w max oh and one 90# battery #2 cable 3' to batt
60HP Evinrude
60HP Evinrude
Gotta sound like a Rock ConcertBassFrequency wrote:CT Arrow wrote:Hmm, 1000 watts @ 13.8 Volts is around 72.5 amps an hour of draw
- BassFrequency
3rd place at the lake, recently metered at 129.4 dB in the famous words of twisted sister, I WANNA ROCK!!!CT Arrow wrote:Gotta sound like a Rock ConcertBassFrequency wrote:CT Arrow wrote:Hmm, 1000 watts @ 13.8 Volts is around 72.5 amps an hour of draw
60HP Evinrude
60HP Evinrude
Im going to try this 250 watt amp for a while with 4 6x9's on it and the 2 6 1/2" speakers off the stereo. may leave the 2 existing 6 1/2'' speakers to make it 4 6x9's and 4 6 1/2's all together. SHould have plenty of sound to hear it while running and way more then needed when stopped.CT Arrow wrote:Hmm, 1000 watts @ 13.8 Volts is around 72.5 amps an hour of draw
Well so far the 4 jbl 6x9's on a 240 watt Pioneer amp and 2 6.5" jbl's on the stereo sounds freaking great. Loud and clear with a nice bass tone . SPeakers are mouted in each satee and produce a lot of bass for a small speaker from such a big encloser.
THis is listening inside my 30x40 metal shop, The real test will be this weekend out on the water, the amp is only half way turned up. if it needs more, ill turn it up and maybe later change it for a bigger amp and add a sub.
Right now, im completely happy with it.
- BassFrequency
good to hear its coming together
just remember, it can always get louder and wire size makes a huge difference.
example: BF used to have 14awg wire amp to subs. swaped it out for 8awg and gained better clear response and +5dB at the cockpit
what size power cables are you runing to your amp? you dont wanna starve it
60HP Evinrude
60HP Evinrude
[quote="BassFrequency"]good to hear its coming together
what size power cables are you runing to your amp? you dont wanna starve it [/q
i Am running 8 gauge power wires but only 3 feet to battery. speaker wire is 12 gauge, I thought about running bigger but for 6x9's i figured 12 was good
If i swap out this amp for a bigger amp, ill go bigger on the power cable and when i add a sub ill keep that in mind to go big on the speaker wires.
I actually want to add a sub in each front couch facing back towards me. Will it be ok to share a box (couch) with the front 6x9's? i am using a free air sub when i do it and probably going with a jbl 10" marine sub on each side.
- BassFrequency
with that size of enclosure i dont see it hurting anything. thats how mine are riggedAint Skeered wrote:Will it be ok to share a box (couch) with the front 6x9's?
60HP Evinrude
60HP Evinrude
