Brand new to this site
Check in here and say hi!
Re: Brand new to this site
#16 Post by badmoonrising » Mon Jul 12, 2010 7:40 am
lakerunner wrote:If the Premier is nice I would go that one
I agree, the Yamaha motor doesn't require much winterizing. The I/O does. It will also be a bit more fuel efficient.
#17 Post by badmoonrising » Mon Jul 12, 2010 7:43 am
smalljaw wrote: Also, excuse my ignorance, but what exactly is "dieseling"?
Dieseling is when you turn the key off on the motor continues to run briefly solely on compression...also called "run on". Doesn't happen in fuel injected motors, only carbureted motors.
OlJim
#18 Post by OlJim » Mon Jul 12, 2010 11:08 am
Dieseling is when the engine continues to run after you turn off the key. Numerous causes, carbon deposits, low grade fuel, or as BMR said carburetor needs adjusting, also on older engines having timing set too fast.
Jim
2007 Suntracker PB 22
Regency Edition
MororGuide TM 55lb. Thrust
With Wireless Remote
Humminbird 737 Locator With GPS
90 HP Mercury
