Tent On Toon
TexasTooner
Tent On Toon
#1 Post by TexasTooner » Tue Feb 19, 2019 6:06 pm
Hi All,
Its been a long time since I've posted - lost my login and took me a while to figure it all out - good to be back. So, here is what I'm thinking.......
As in my signature, I have a 25'Lx 8.5'W Tri-toon and I can't afford the whole camper enclosure. I have read a few posts about using a small tent on the front of the toon, but I want to put a Tent over the whole damn thing.
I found a 25'L by 10'W camping tent that I'm thinking of using. I have double biminis, so my thinking is to cut the floor out of the tent, take the poles out and lay it across both biminis so I wouldn't need the middle pole support, but will at the ends, let the sides hang down, add snaps and then add fiberglass poles where needed to add rigidity.....
Okay - has ANYONE done something like this or am I as crazy as I sound.......
Thanks !!!
Captain StarLord of the vessel Stargazer
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
Re: Tent On Toon
#2 Post by curtiscapk » Wed Feb 20, 2019 7:08 am
Welcome back!!!! Check these out yours should work!
viewtopic.php?f=2&t=25282&p=207394&hilit=tent#p207394
TexasTooner
Re: Tent On Toon
#3 Post by TexasTooner » Wed Feb 20, 2019 4:31 pm
Thanks Craig.
Well, looks like I might be a first to try this idea. I’ll post some pics when I get ere’ done !!!
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
r&s20
Re: Tent On Toon
#4 Post by r&s20 » Thu Feb 21, 2019 6:01 pm
i think it would work
but are the sides tall enough that they would hang down far enough ? i think you could make it work if you cut the floor i a big X type pattern, put up and then trim floor to fit
fish and cruise
I am not ADULT SUPERVISION !
TexasTooner
Re: Tent On Toon
#5 Post by TexasTooner » Sat Feb 23, 2019 7:47 am
Ok All,
I done got er’ ordered, meaning the camping tent...... it should be in before too long and I’ll have to open er’ up and study er’ first and devise a plan on how I’m going to do this...... and if it’s feasible before I start doing anything else......
If it does work, which I’m hoping it will..... then we’re off for some new adventures!!!
Keep you all posted
StarLord
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
TexasTooner
Re: Tent On Toon
#6 Post by TexasTooner » Tue Mar 05, 2019 8:35 pm
Ok, the tent is in, but it’s been too cold to setup outside.
My thoughts are to set it up first to see how all the poles setup so I can have a plan on moving it to the pontoon ...... it’s gonna be fun no matter what !!!!
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
Henpecked
Re: Tent On Toon
#7 Post by Henpecked » Tue May 14, 2019 9:07 pm
If you have grommets or stake loops along the bottom of the tent, you can bungee to the floor supports that go between the floor and the pontoons. That will keep tension on the tent walls, but tie the corners down hard at the tie down points. I hope you have zippered screen windows in the tent for ventilation.
You can wrap the base of the tent around the poles and tie the poles down to the deck. It will spread the force on the tent wall across the whole distance instead of tearing at single points of attachment. The biminis will be supporting the tent.
coherent
Re: Tent On Toon
#8 Post by coherent » Tue Aug 18, 2020 5:35 am
Did you ever complete this? Did it work? Pictures?
John Pen
Re: Tent On Toon
#9 Post by John Pen » Tue Aug 18, 2020 6:49 pm
We are also interested. Looking to do some sort of sleeping arrangements on ours, and as we are at the head of a rebuild, now would be a good time to make any necessary mods
