fish locator/depth finder
killerkernrich
#1 Post by killerkernrich » Fri Apr 11, 2014 8:47 am
I fish fresh water only, have a garmin 300c it is not working good enough, it fails alot it will be doing ok showing I am in 15 ft h20, then it goes to 1ft showing fish @8ft down in the mud??? it will go good for several minutes then goes nuts over places that I have been many times.
I will be upgrading soon
What does the masses on here like the best
I would like to stay under $1,000
PLP Member
NRA member
UFC fan
steveiam
Re: fish locator/depth finder
#2 Post by steveiam » Fri Apr 11, 2014 4:36 pm
This will change fishing forever for you.
I have an HDS 8 and love it but my buddy has one of these and Like it better.
Learning to use the side image feature has REALLY helped my fishing.
http://www.basspro.com/Humminbird-899ci ... _THUMBNAIL
bobalong
#3 Post by bobalong » Fri Apr 11, 2014 11:13 pm
I have the Humminbird 898 (last year model) and am very happy with it. Some new upgrades for these and other Humminbird units this year as well.
2011 Sweetwater 206F Sunrise
2011 60 HP Evinrude Etec
Humminbird 798SiHd
Boating on Moose, Pigeon, Lac St. Anne and Sask Landing
killerkernrich
#4 Post by killerkernrich » Sat Apr 12, 2014 7:18 am
If I have a Garmin mounted now, if I put a H-bird in its place would it work using wiring & transducer that is already there from the Garmin??
PLP Member
NRA member
UFC fan
bobalong
#5 Post by bobalong » Sat Apr 12, 2014 9:39 am
killerkernrich wrote:If I have a Garmin mounted now, if I put a H-bird in its place would it work using wiring & transducer that is already there from the Garmin??
Garmin, Humminbird and Lowrance will have different connectors on the sonar end, and probably operate at different frequencies as well, so you will need to run the new cables. You will able to just connect the power cable to your old feed, as they all operate on 12V but the transducer will have to installed.
Humminbird 798SiHd
killerkernrich
#6 Post by killerkernrich » Sat Apr 12, 2014 11:27 am
I figured as much ...Thanks... I may just stick with Garmin
PLP Member
NRA member
UFC fan
