32' Suntracker Party Cruiser partial rebuild but I need help
These are some of the pics of my rebuild but now I really want to make some other changes to it but I just don't know where or what to use. I want to take down the sides and put up new ones because these are really cheap and they look like they are taking on water. Any recommendations would be greatly appreciated.
- back home in her slip at Don Pedro. Now just praying for continued water.
- finished in water.jpg (38.09 KiB) Viewed 3409 times
- finished rear siding.
- finished right side.jpg (27.56 KiB) Viewed 3408 times
- new swim deck was added.
- swim deck.jpg (27.79 KiB) Viewed 3410 times
- new Kitchen cabinets from Ikea and top from Home Depot.
- kitchen cabinets.jpg (32.06 KiB) Viewed 3408 times
- heavy duty aluminum supports for the new hard back.
- supports for back.jpg (31.59 KiB) Viewed 3408 times
- of course I took everything off of the front and removing the carpet was by far the hardest thing to do. I replaced it with a lightly sanded, self leveling floor.
- self leveling floor.jpg (25.98 KiB) Viewed 3409 times
- another before picture. Those canvas tops don't last long and are very expensive.
- small image before rebuild.jpg (59.99 KiB) Viewed 3410 times
- of course this is a before picture.
- front before rebuild.jpg (71.32 KiB) Viewed 3409 times
- just pulled it out of the water and moved it to the repair yard.
- before left side.jpg (55.79 KiB) Viewed 3411 times
Re: 32' Suntracker Party Cruiser partial rebuild but I need help
Weight going forward is going to be the critical factor in anything you attempt to do with your pontoon. In observing the photo of it floating as is it's already at critical mass. I can't actually suggest what may be the best materials to utilize for your needs myself. But there is a forum I used to frequent that some members did successfully rebuild some party huts. I'd suggest you glean the rebuild section there for some insightful ideas. I'll paste a couple links below but I didn't take the time to find the biggest and best one there, but then again they may have taken it down.
http://www.pontoonboatforum.com/sunbloc ... c3192.html
http://www.pontoonboatforum.com/sun-tra ... c7167.html
http://www.pontoonboatforum.com/2000-32 ... c8329.html
Wishing you success and please keep us in the loop with your progress.
[quote]Weight going forward is going to be the critical factor [/quote]
Bamby is right, Looking at the water marks(small image before rebuild.jpg) on the logs, "critical mass " is what came to my mind as well.
The "Sunblocker" will give you an Idea about what he was talking about.
