1973 16' Harris FloteBote Rebuild
We started with a 16ft 1973 Harris FloteBote with a 55hp Johnson Outboard. The great thing is we picked this boat up for $1,000.00 and only had to drive about 25 minutes to get it. It had great aluminum, but everything else was pretty much garbage. Here are some pics of the day we picked it up:
Here we begin to tear down the boat to the aluminum logs and cross channels:
Here we have removed the railings from the deck. Our railings were attached with carriage bolts on top and standard nuts on the bottom. Once these were removed the railings were easily removed from the deck.
3/4 View of Completely Deconstructed. In this step we removed the plywood decking and everything that was on top. We took a grinder and cut off the bolts from the bottom side of the boat. You may need to pull your carpet up and determine how your deck is currently fastened, as not all pontoons were built the same.
We decided we would grind down the rust on top of the channels with an angle grinder and give them a good coat of Rustoleum Spray Paint to prevent furthur corrosion. This can be found at any home improvement store for about $3.00 a can. *Notice the front half of the pontoon compared to the rear. The front has been cleaned with Sharkhide Aluminum Cleaner and is neatly restored to a dull grey color. We will polish the toons with the Sharkhide Polish a little down the road.
We then added the decking. We used our 4'x8' CCA Treated Marine Grade Plywood. We secured the decking to the cross channels with our 2" Stainless Steel Deck Screws.
Next up was a 22oz Marine Grade Carpet
RECONSTRUCTION, FINALLY!
David
Re: 1973 16' Harris FloteBote Rebuild
Good job, I'm still working on mine
I swear its never ending, I just picked up an early 90's Harris from a relative, plans to really take this one to the next level with some of our new products here at the shop! Pics coming as soon as it warms up haha!
David
Hmm... What's missing from this picture?
ARe all pontoon aftermarket companies in Elkhart????
Haha yes, seems that way! That's where all the pontoons are built, so we have easy access to tons and tons of OEM vendors!curtiscapk wrote:ARe all pontoon aftermarket companies in Elkhart????
David
He got the remote control, he don't need no steering wheelBobG wrote:Hmm... What's missing from this picture?
Good job, looks nice.
- Texoma Toon
Looks good!
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
90 Hp Yammy
Dual Axle Trailer
