1992 Vibo Recarpet
Re: 1992 Vibo Recarpet
Ended Up cutting the welds on the 4 corners to get those off. Now I need to find some sort of bumper caps to put over them. Carpet is in. But now I'm in a holding pattern. Some of the wood structures of the furniture was rotted out. So I decided to order a new interior. It should be here Friday or Saturday.
1992 21' Vibo DLX with 40hp oil injected Merc Mariner
Good to hear that cutting the welds worked. Still cant believe they welded it while on the plywood. I would of guessed that the heat might start the wood on fire.
Did you bother to glue the carpet down? I plan on doing my carpet today and decided not to bother. Mainly because the plywood will need replacing in a couple years and I would like to reuse the carpet.
Yes I did glue it down but only around the out side and two strips down the middle. Plenty of furniture in there to keep it from moving around.
Finally an update. Pretty much all done except I will need to replace the vinyl on the sundeck and bathroom door to match the new vinyl.
Ended up removing all the pin stripping and painted the fencing....what a PAIN.
- newresize5.jpg (158.06 KiB) Viewed 2844 times
- newresize4.jpg (136.15 KiB) Viewed 2845 times
- newresize3.jpg (149.91 KiB) Viewed 2847 times
- newresize.jpg (209.15 KiB) Viewed 2844 times
- newresize2.jpg (163.82 KiB) Viewed 2846 times
Good job looks nice.
