Motor Swap
FireEMT41
Motor Swap
#1 Post by FireEMT41 » Wed Aug 07, 2013 1:03 pm
How hard is it to take the old motor off and switch it with a higher HP motor? I'm assuming that would mean I have to change out controls also? Never done this before. A little worried about trying to do it.
[color=#4000FF][i]In case of fire, yell "Fire!"[/i][/color]
Re: Motor Swap
#2 Post by HandymanHerb » Wed Aug 07, 2013 1:14 pm
If you stick to the same brand engine you won't have to change out controls
redbeard
Re: Motor Swap
#3 Post by redbeard » Wed Aug 07, 2013 2:08 pm
You'll need a cherry picker take about a hour maybe less but not bad.
Re: Motor Swap
#4 Post by margaritaman » Wed Aug 07, 2013 4:29 pm
I used an engine hoist.
Re: Motor Swap
#5 Post by badmoonrising » Wed Aug 07, 2013 8:00 pm
I used one of our 100 plus year old beech trees and a come along to drop the I/O motor into my Starcraft :prayer :rofl :rofl
MH Hawker
Re: Motor Swap
#6 Post by MH Hawker » Mon Aug 19, 2013 8:43 am
It isn't expectantly hard, if its a different brand of motor you will need to switch the controllers to, but its all plug and play If its the same brand it can depend on the age some of the newer ones arnt comparable with older ones.. In my case I buy the motor and matching controller. If not you can run into plugs and cable ends that don't match, all ways check.
Re: Motor Swap
#7 Post by lakerunner » Mon Jan 20, 2014 4:31 pm
At one time Honda and Merc could use each others shift box
