painting rails?
spursfiend
painting rails?
#1 Post by spursfiend » Wed Mar 25, 2015 8:27 pm
Hi all!
New guy here and really enjoying all the restores. I recently purchased a 24ft '93 Beachcomber with a 120 Johnson and am doing a little work fixing it up with new console, fence panels, Marideck, bimini, etc. I see that some of you folks have painted your railings. My rails currently have the stock silver aluminum finish. I'd like to paint mine (flat khaki) and am curious what kind of prep work y'all did before painting. Sanding? Sand blasting? Primer? Wipe it down and spray? I want it to look good and hold up for a while.
I promise to post pics!! 8)
ToonGuy
Re: painting rails?
#2 Post by ToonGuy » Thu Mar 26, 2015 5:15 am
Low buck: Sand, rattle can prime, rattle can paint. This method will scratch fairly easily.
Better: Sand, etch prime, automotive paint with hardener. This method is durable.
Best: Sand blast, professional powder coat. This method is VERY durable, and will last a long time. And is the most expensive, and you will most likely have to farm out ALL of the labor.
Re: painting rails?
#3 Post by RcgTexas » Thu Mar 26, 2015 8:13 am
First of all Welcome! I am concerned that unless you powder coat those rails you may be opening up a can of worms. Fixing spots and repainting scratches might be the product of painting rails IMHO.
spursfiend
Re: painting rails?
#4 Post by spursfiend » Thu Mar 26, 2015 3:46 pm
Thanks for the welcome and information! Option 2 was what I was thinkin. Powder coat is out of my budget. If the scratch maintenance gets overwhelming, I've got a 4000psi pressure sprayer that should handle the removal.
ToonGuy
Re: painting rails?
#5 Post by ToonGuy » Fri Mar 27, 2015 5:32 am
I had my toons and rub rail etch primed and automotive painted on the second boat I ever built. It held up fantastic. I kept it in the water all summer for 8 years and other than a few very minor nicks & scrapes it looked new. Think of it this way...if you prep and paint properly it's no different than a car and they look fine for years if taken care of.
Mrtoler
Re: painting rails?
#6 Post by Mrtoler » Sat May 02, 2015 10:14 am
Ive used method #2on the last three toons I've built and plan on using it again on the fourth. Just spend the time and prep the rails to the best of your ability, it'll be worth it in the end... We always used lacquer thinner to clean them really good before we painted.... Use a good etching primer, should look nice!
2006 dodge ram quad cab
Crosby Texas
Re: painting rails?
#7 Post by Bamaman » Sat May 02, 2015 2:50 pm
Most of the painted rails appear to be on the Bentley Encore pontoons. I still prefer the silver anodized finish that most other brands use.
I really think those painted rails hurt Bentley sales dramatically. You can now get'em anodized or painted from them.
Mrtoler
Re: painting rails?
#8 Post by Mrtoler » Sun May 03, 2015 10:14 am
This past boat show I noticed a new theme. There were several boats with powder coated tubes as well as rails, they all had large crowds gathered around checking them out. I think it gives it a much sportier look. But that's why they make all kinds, it would be a boring world if we all liked the same thing
Crosby Texas
ron nh
Re: painting rails?
#9 Post by ron nh » Sun May 03, 2015 12:38 pm
Yes, they look great. some of the sylvans are beauties. they'll all offer them soon. probably next year since I bought this year. :donno
