Vinyl wraps
Vinyl wraps
Here are a few boats I've vinyl wrapped. Just thought you guys might want to see.
- IMG956945_01.jpg (257.45 KiB) Viewed 4804 times
- IMG_20180827_065113_01.jpg (1.15 MiB) Viewed 4804 times
- IMG_20180827_065120_01.jpg (1.15 MiB) Viewed 4804 times
Re: Vinyl wraps
Great job and welcome too the club! More pics!
Re: Vinyl wraps
They look great. I have my eye on a friend's old boat and it is very similar to your middle picture. The rails were damaged in a storm and he has already bought a new boat. I suspect that I will be replacing the skins if I get it and won't need to wrap, but it's good to have options. Is it hard to install? Do you remove the skin, wrap, and reinstall, or do you install the wrap in place? Heat gun?
Re: Vinyl wraps
Any word on how well the vinyl wraps hold up on Florida Gulf of Mexico salt, sun, etc.? Have been thinking about wrapping my Bennington.
2012 Bennington 24 SSL
150 HP Yamaha
.45 1911 Security System
150 HP Yamaha
Re: Vinyl wraps
It's not too bad to install! However I have been doing vinyl for signs, cars, boats and much more for 17 years. I have a little experience. I use heat when needed but don't usually need much. I leave the skins on and hand cut edges if needed.Henpecked wrote: ↑Mon Aug 27, 2018 4:33 pmThey look great. I have my eye on a friend's old boat and it is very similar to your middle picture. The rails were damaged in a storm and he has already bought a new boat. I suspect that I will be replacing the skins if I get it and won't need to wrap, but it's good to have options. Is it hard to install? Do you remove the skin, wrap, and reinstall, or do you install the wrap in place? Heat gun?
Re: Vinyl wraps
I would think it would hold up just fine! Most graphics on boats are already vinyl. A high quality vinyl definitely helps.
Re: Vinyl wraps
I had a custom WVU wrap on my last boat and really liked it. It was a real head turner with incredible detail. It even had the lyrics to Take Me Home, Country Roads "ghosted" in the background. The guy who did it (a pro) said he'd never wrap another pontoon because it took so long to remove the original graphics. Might have been harder because the boat was about 10 years old when he did it.
None of the colors faded in the SC sun. However, a wrap is a big vinyl bumper sticker. Even though mine was a high quality 3M vinyl, it really took a beating after 7 years. About every panel had some kind of gouge in it. Most I never knew what happened.
Re: Vinyl wraps
This one’s over three years old now:
- 080649D0-3236-481D-9779-DFC1CED674DD.jpeg (814.07 KiB) Viewed 4592 times
