Mounting location for a depth / fishfinder
- partybarge21
I have received my new depth / fishfinder.
I was thinking of mounting it on the back of the pontoon that has the mount for my well pump. The bracket that covers the pump seems to have plenty of room to drill and mount the underwater sensor on. Using the cover to mount on allows me not to put any holes in the pontoon and hence no possiblity of leaks.
Were do you guys have yours mounted?
2000 Tracker Fishin Barge21
Cruzin Lakes Bay, NJ (Atlantic City NJ)
"Life is a trip without a road map"
Re: Mounting location for a depth / fishfinder
Mine's the same as Rick's.
same as Ricks but on the starbord side
Mine is same as paulangelo's
- looneytoons
Same here!
Thats the right place to put it!
Ive already got one there for my depth finder.
I want to add a fishfinder/gps now and i guess im gonna have to figure out a way to share the existing transponder.
Havent figured that one out yet...
Colorado Springs, CO.
- partybarge21
Hey Guys,
Thanks for the info.
That is exactly where I was thinking of mounting it.
Rick, I printed out the picture for reference. (I didn't say I was bright. I need reference )
same as mine too
Does anyone have any ideas for a front mounted depth finder? I already have one on the stearn of the boat that goes down several inchs. I need one on the front so as to keep the one on the back (90 Merc) out of the mud.
Thanks,
Tom
Thanks,
Tom
Tom
Tenn-Tom Waterway, MS
2008 Bentley 240 Cruise 90hp 4S Mercury
14' Polarkraft river boat 18hp Nissan 4s
Kept in boat house in front yard
I have a similar original factory installed Garmin mounted like most - to the pump bracket. I added a second Humminbird to the transom - see image. I found that it gets much less turbulance and hence much, much better high speed performance than the one mounted to the port side log pump bracket. I don't know if your transom is set up like mine so I can't say how it will work.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
