Changing oil
Lindsay90
Changing oil
#1 Post by Lindsay90 » Tue Apr 11, 2006 9:53 am
Ok I know most of you have changed oil yourself but here is what I need input on. I have no worries about doing maint on the motor (75hp 4-S ) but I have had the boat in the water for a summer and a half and think it is time to change oil and gear and spark plugs. I got it brand new and never changed nothing, should I take it in for at least for one good maint going to cost $275.00 and then I do it myself later in life?
Toontroller
#2 Post by Toontroller » Tue Apr 11, 2006 12:26 pm
Lindsay90 I would ask what they do for the $275.00, if this includes readjusting all controls and linkages then it might be worth the extra money the first time. If not I would be inclined to purchase a good maintenance manual for my engine and do the work myself.
1991 Sun Tracker Bass Buggy 16
Evinrude 40
Bet I have the shortest Toon on this board also
Lindsay90
#3 Post by Lindsay90 » Tue Apr 11, 2006 1:01 pm
I know for that price all oil (lower and upper ) grease and new spark plugs but good call on adj things like the steering wheel I will check into that. I just want to know if that price sounds about right and what do you guys pay if you were to do it yourself? I mean if I am going to save 50 bucks doing it myself well better to have a trained guy do it then.
Lindsay90
#4 Post by Lindsay90 » Fri May 19, 2006 7:32 am
Ok I was a tight a$$ and did the maint myself but guess what.... now I have to take it in cause she does not idle right and seems to be missing. So you guys were right should have took it in the first time :x :oops:
Lindsay90
#5 Post by Lindsay90 » Thu Jun 08, 2006 12:26 pm
Ok update two bad carbs but they went through all four. It pays to use Stabill next time much cheaper.
