Aluminum Struts and Supports in Ski Locker
Drago
#1 Post by Drago » Mon Sep 10, 2012 4:45 pm
I found the battery dead (I left the Perko Switch on) the other day. When I hooked up the charger, I heard a strange noise. Turns out it was the pump in the ski locker running. I could not get it to quit so found the fuse inline and killed power to it. It was on its side in the locker. Looks like it had come loose from the bottom of the tube where it was glued on.
In my investigations, I found all the aluminum supports and struts that hold the synthetic boards in place had come loose. This is still a warranty issue but I'm trying to save a trip and time so I want to ask here. All the stuff looked like Bennington had used some sort of adhesive to affix the struts and supports to the bulkhead and walls of the tube. Just wondering if any ideas on adhesive to use to fix aluminum to aluminum.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
