starcraft 20ft pontoon speed
Re: starcraft 20ft pontoon speed
Hmmmmmmm...something is different about BMRs aviator. I suspect the wifey may have had a hand in that.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
Lol....no she had nothing to do with that. Neither woman in that avatar was her and same for my new one. Who do you think took the photos ??
Are you measuring your speed via GPS or your speedometer? Speedos are notoriously wrong.
My 22ft toon with 25" logs and a 90 hp Yamaha with just me and 25 gals fuel in the spring will get 25 mph at 5900 rpm's. Now after being in water all the time, best I get, same condition, 22 mph at 5600 RPM's. Dirty toons, hot weather less speed. Your in the ball park with your speed. Would have to spend lot's of bucks to pick up a few mph in my opinion.
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
i got my 22ft odyssey with 75 merc up to 23-24 mph sat with 2 adults 3 yrold and cooler and 20gal gas. with no people up front trims out nice. wonder if i put bimini down get more mph..
Re: starcraft 20ft pontoon LACK OF SPEED
I have a 2009 Merc 90 four stroke that gave me a whopping 16 MPH via GPS over the weekend. The load was with 2 guys about 170 pounds each and 2 women about 120 each. 1/4 tank of gas and WOT is at 6200
I think I want to burn my boat Please someone pull a rabbit out of a hat and tell me what is wrong. Im not looking for a speed boat but I would figure I should get more than 16 MPH
Thanks
Thanks
Is your boat new as well? If it is an old boat with a new motor could you have water in your toons? You should be getting more than 16 for sure.family pontoon wrote:I have a 2009 Merc 90 four stroke that gave me a whopping 16 MPH via GPS over the weekend. The load was with 2 guys about 170 pounds each and 2 women about 120 each. 1/4 tank of gas and WOT is at 6200
Thanks
Post some pictures of it in the water. Could the prop be gravitating?Im also being told the front of the boat sits low like its taking a nose dive.
We get 17 mph with 2 adults and 30 gal. of fuel and thats with a wimpy little 40 hp merc.
drops real fast when we add more people . can't wait to get that 75
Jeff & Donna
2006 tracker bassbuggy
Lake Pend Oreille Idaho
PLEASE HELP starcraft 20ft pontoon lack of speed
I'm about to burn my 20' Starcraft pontoon boat. Heres what I have and hope someone can shed some light on it.
2005 206 ELITE with a NEW Merc 90 Four Stroke. I have contacted merc and several local boat stores and everyone is telling me to use the same prop which I have installed (dont remember dia and pitch). Boat full or with 2 aboard, can get the thing above 15MPH and no way will it get up on plane. The boat is really pushing the water and on several occations, the front end has dove into the water like a submarine when I have pulled back on the throttle. Water pours onto the front deck and people panic.
I have checked the tubes for water and they are empty and hold pressure. I have raised the motor to the highest mounting point from the lowest and seemed to make it worse.
Guys and Gals, your my last option before I post pictures on ebay and craigs list for Boat for Sale minus motor
My 2010 Starcraft 22 foot with a Yamaha 90 HP 4 stroke will do about 27 mph GPS.
90 HP Yamaha 4 Stroke
Ocean City, Maryland
Family Poontoon, I had a 24ft Starcraft with 120 h.p. Johnson. This boat was a dog it did just like yours, nosedived under like a WWII german Uboat. I had to have the motor rebuilt 3 different times due to melting pistons. I have owned a Starcraft ski boat and it also had a lot of problems only with handling. It was 14ft deep V with deep sides and rated for a 60h.p. which it had. After I wore out the 60 I put a 85h.p. Johnson on it and that transformed that boat in a great riding and handling boat. I think that Starcraft is junk and this is just my opnion.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
Elm Grove, La
Lake Bistineau
I agree Starcraft is junk but for now Im stuck with it. I just looked and the prop is a 14 x10
JUST A THOUGHT!! The Merc I have is a short shaft, does every pontoon run short shaft? Im I crazy to think I should have installed a long shaft motor???
OLD BOATER starcraft 20ft pontoon speed
Old Boater, Can you give me more details on your boat and motor?? Not sure what to ask but how about prop info, year of the boat, size of the tubes.... Im new at this and grasping for straws. Please toss out anything you think of
thanks !!!!
thanks !!!!
Hey guys does anyone have one of those whale tails mounted to the lower end of the motor??
any ideas or suggestions pleaseeeeeeeee!
