Page 3 of 3
Re: How many of us are running a dual battery setup?
Posted: Mon Sep 17, 2018 8:21 am
by guy48065
Glad I switched back to a 2-battery setup. I hadn't used my boat since July 4th but found the battery dead this weekend--even though it was switched OFF. It would have been a bummer having to wait several hours for it to charge before I could take it out. AND now I can't trust THAT battery.
Posted: Mon Dec 14, 2020 2:28 pm
by fiddlebick
I added a second battery, a switch, and an Blue Seas auto charging relay.... a few years back. We boat a fair amount of time on the Ohio and a dead battery is no fun on a river when the current is strong. The Blue Seas setup automatically charges both batteries when it senses voltage from the charging system. When the key is off, the relay isolates the "house" battery to run the accessories I use, mostly a nice stereo. The second you turn the key, the start battery is again active and running the show, and the house battery is being charged again. A flip of the manual switch and I can combine both batteries in case my start battery were to get weak. I've learned that thinking ahead pays off when dealing with boats, and worth the expense for my peace of mind. I have a knack for bad things happening unannounced.
Posted: Mon Dec 14, 2020 3:52 pm
by lakerunner
I run a dual setup also and use a minkota dual charger. I have it set on a timer so it only runs 1 hr a day. I worry about it being on all the time. I am 2 hrs away from where we store the boat
Posted: Tue Dec 15, 2020 7:23 pm
by vlxerdon
very old thread. I added a second batt with a Perko switch. As has been stated, a dead batt is no fun.
Posted: Thu Dec 17, 2020 4:06 am
by hoejef
Just added second battery with perko 1-2 both switch as I purchased boat in Sept. have add ons that i have been doing and more for future.
Plus peace of mind knowing I always can get motor started
Posted: Tue Dec 29, 2020 11:32 am
by UteSundeck
My boat came with a dual battery set up and the traditional Perko selector switch. I changed out to Odyssey AGM batteries, one large main Odyssey
- Batteries.jpg (83.02 KiB) Viewed 3516 times
PC1800FT its huge and heavy, and a small secondary Odyssey PC1500. I can run my stereo alone on the main battery for hours and hours and have never had to switch over to my secondary battery to start back up.
I did also add a hellroaring battery isolator thought that I would definitely recommend.
