WOT RPM range
WOT RPM range
I have a 1998 Johnson 150 motor, does anybody know where I would be able to find what the RPM range is for this engine? Every chart I have found does not go prior to 2006 on the 150. Any help would be appreciated. Thank you.
JEB
NEW-2019 Barletta L25UC
2019 Mercury 300 4 Stroke
EZ Loader trailer.
1985 Starcraft SD240
New to me-1998 Johnson 150 carbureted
Traded in-1979 Johnson 140
Upgraded transom
Added cross members
Glen Rose, Texas
EZ Loader trailer.
Upgraded transom
Added cross members
Glen Rose, Texas
Re: WOT RPM range
I'd suspect between 5-6K....if you don't have a service manual, I'd suggest you get one...
Re: WOT RPM range
[quote="JEB"]I have a 1998 Johnson 150 motor, does anybody know where I would be able to find what the RPM range is for this engine? Every chart I have found does not go prior to 2006 on the 150. Any help would be appreciated. Thank you.[/quote]
Most things I Googled --forums, iboats say WOT is 5500rpm with operating ranges between 4500-5500... Try to set it up depending on boat toward the upper limit of operating range. My 2009 90 hp Merc top end is 5800-5900---and if you hit it you get an alarm--not sure about the older motors. Good luck....
Usually running a motor at WOT and getting lower rpm's than what manufacturer states for motor is not good for motor. Major contributor is the prop.. Changing pitch of my prop by 1 inch on my pontoon boat makes a difference of around 350 rpms..
Again--raising or lowering engine on transom and changing props/pitches etc are the main things you can do to change boat performance.
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
90 Merc Optimax
Underskinning
28 GPS
Re: WOT RPM range
Somewhere inside the engine cover, the rpm range is usually noted. 5800 is about normal on 2 strokes.
Re: WOT RPM range
Those old 2 strokes pretty sure were 5500. Even the newest 2 strokes do best around 5600 to 5800.
