First time out, have some problems...
So we took her out. Love the boat, all the room and storage is great. We have some kind of problem with the motor. Idles fine and will run slow but try to give it the gas and it bogs out. No take off or power at all. I'm going to check all the lines to see if there is a leak. Was thinking it could be bad fuel, don't know how long it has set up. Any things else you think it could be?
Other then that my dogs had a great time. I got 2 mini doxies and a golden retreivier. My two older dogs have been out on the river many times. The youngest doxie just had a grand time. He took right to the water and the boat. I got to get the problems solved and get us all back out there again.
"Water Hawg"
2006 Starcraft Classic 180
40hp Mercury 4 stroke
Re: First time out, have some problems...
Bad Fuel
Fuel Filter
Dry rotted lines
The primer bulb could be closaping
Plugs
Would be some basic areas I would check
Fuel Filter
Dry rotted lines
Plugs
2013 South Bay 442CR STT
150 HP Mercury 4 Stroke
What bruuuuce said AND
if that dont fix it then the carbs will need to be taken apart and cleaned, my 50 did that and i changed everything and finly cleant the carbs and it run like new
DONT let a lil setback discourage you fun.... THATS whats nice about a TOON is ya dont HAVE to go fast to have FUN LOL
1982 Sylvan 24' Toon
50hp Evenruder
my fishin/camping boat
An unarmed man is a subject.
911: Government sponsored Dial-a-Prayer.
When seconds count....Police are minutes away
50hp Evenruder
Sounds like a bad accelerator pump in the carb. Rebuild it and you'll be fine.
HUH??? its a 40 mercbadmoonrising wrote:Sounds like a bad accelerator pump in the carb. Rebuild it and you'll be fine.
I didnt know they had a acc pump
50hp Evenruder
50hp Evenruder
- scfishnman
Two other possibilities - inadequate venting on the fuel tank (try running with the fuel cap off to see if that helps) or a pinhole size leak in the fuel line allowing air to be sucked in.
-- Aqua Patio 240DC triple toon 225 Yamaha 4-stroke
-- 17' Polar Kraft w/ 75 hp Evinrude Etec
-- Yamaha Waverunner FX Cruiser HO
-- Yamaha Waverunner FX HO
Nevermind, I'm thinking I/O...wasn't drinking either. First thing I'd check though is fuel pressure and go from there.sHan tn wrote:HUH??? its a 40 mercbadmoonrising wrote:Sounds like a bad accelerator pump in the carb. Rebuild it and you'll be fine.
Ok ya had me scraching my head for a minbadmoonrising wrote:Nevermind, I'm thinking I/O...wasn't drinking either. First thing I'd check though is fuel pressure and go from there.sHan tn wrote:HUH??? its a 40 mercbadmoonrising wrote:Sounds like a bad accelerator pump in the carb. Rebuild it and you'll be fine.
50hp Evenruder
50hp Evenruder
How about running a can of Sea Foam thru it first, it should help to clean it out and it's cheaper than tearing things apart first.
Had a snowmobile last year that I had not run for two years. Ran like crap when excellerating. added a can of Sea Foam and within a couple hours was running great.
22' AquaPatio 90 4s Yamaha
Port Perry, Canada
Port Perry, Canada
how old is the gas. if its old dump it and put fresh in if freash check lines and plugs.
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
115 Yamaha
karavan Trailer
2014 Chev tahoe
Port Of Bismarck ND
I like the seafoam idea. I think you might have water in the gas. Another cheap fix is to add a fuel water separator kit to the fuel line. $20 bucks or so.
23ft 2007 Parti Kraft, 115hp Yamaha 4 stroke on the Mighty Vermilion River!
Great news called the dealer and complained so they are going to fix it. Should get it back before the weekend.
"Water Hawg"
Sweet that's a helluva dealer on a used toon
