We have a 2005 Hurricane Deck boat. 22' with inboard Mercruiser. On the front there is an outlet for a trolling motor. What would be a good Trolling motor for this boat? Any suggestions? What about shaft length? Mounting location? Wiring? Is the boat wired for a 24v system? Any help would be appreciated!
Thank you!
Trolling motor question
Re: Trolling motor question
I have a 22.5 tritoon. I use a Minn Kota Terrova 80 lb thrust with a shaft at 60”. You can measure the deck to your water line to get a good idea where you want your shaft to measure. This motor works well for me.
2016 Ford F250 6.7
Grizzly Flats, Ca
2016 Ford F250 6.7
Grizzly Flats, Ca
Has anybody used the Minn Kota Power Drive 48" ? I'm thinking 68lb for an 18ft.
