Welding tie down loops to pontoons
Wreck Tangle
#1 Post by Wreck Tangle » Tue Jun 26, 2018 1:15 pm
Is it possible to weld a "tie down" loop onto the front end of my left and right pontoons?
My boat only has a loop on the center 'toon.
Any idea what the cost would be?
over/under 500?
over under 1000?
couple hundred bucks?
Re: Welding tie down loops to pontoons
#2 Post by bansil » Wed Jun 27, 2018 4:03 am
I would def. get it TiG welded on, a mig with a spool gun would probably go through the thinner metal
What will these be for? actually tieing down to a trailer? or for dock lines? if dock lines I would through bolt some cleats onto deck
rancherlee
#3 Post by rancherlee » Wed Jun 27, 2018 5:14 am
What’s the intended use? Mine has aluminum cleats welded on the tips and Only use them for trailer tie down, and use the deck cleats for the anchor. If your looking for hooking up trailer straps I’d just get a set of stainless u bolts and bolt them on the inside of the front risers. The U bolts like the ones found on the back of runabouts for tie down use. They usually come with a nice stainless backer plate also.
