Floor replacement question
psrujak
#1 Post by psrujak » Sat Apr 20, 2019 5:58 am
When I took the floor off the 97 pontoon the front section I found a 4x4 bolted to the front of it with a large eye bolt. This was used to connect the winch to. What is the right way to do this or do I use the same setup? I am waiting for marine grade plywood to arrive. Any help or suggestion would be appreciated.
Re: Floor replacement question
#2 Post by lakerunner » Sat Apr 20, 2019 6:18 am
I would use a 1/4" aluminum angle across the width of the toon, bolt it to cross member
psrujak
#3 Post by psrujak » Sat Apr 20, 2019 7:15 am
Would 2x2x.025x8 work?
#4 Post by lakerunner » Sat Apr 20, 2019 11:32 am
Don't know why not
psrujak
#5 Post by psrujak » Sat Apr 20, 2019 2:15 pm
lakerunner Thanks for your help. I will order the metal.
guy48065
#6 Post by guy48065 » Mon Apr 22, 2019 6:40 am
.25" I hope. .025 would be...aluminum siding trim? Don't order that...
:biggrin2
Mark
Rush Lake, Atlanta, MI
