Floor replacement question
When I took the floor off the 97 pontoon the front section I found a 4x4 bolted to the front of it with a large eye bolt. This was used to connect the winch to. What is the right way to do this or do I use the same setup? I am waiting for marine grade plywood to arrive. Any help or suggestion would be appreciated.
Re: Floor replacement question
I would use a 1/4" aluminum angle across the width of the toon, bolt it to cross member
Would 2x2x.025x8 work?
Don't know why not
lakerunner Thanks for your help. I will order the metal.
.25" I hope. .025 would be...aluminum siding trim? Don't order that...
Mark
Rush Lake, Atlanta, MI
