Drain Holes in plastic seat bases
DirtinLa
#1 Post by DirtinLa » Sat Jul 27, 2019 12:42 pm
Hi,
I just got a used 2006 suntracker 21signature party barge and I'm redoing the vinyl. While pulling the seats I see allot of sitting water in the bases of the furniture. Any reason for me not to drill drain holes so the water runs. For now and into the future?
Thanx in advance,
-=Fred=-
*** MY PET PEEVE *** If you ask for help and help is given be so courteous as to post how you finally fixed the issue.
Re: Drain Holes in plastic seat bases
#2 Post by lakerunner » Sat Jul 27, 2019 2:34 pm
I did and also drilled holes in the bottom of the seat base
teecro
#3 Post by teecro » Sat Jul 27, 2019 2:50 pm
Our Sun Tracker had a few drain holes drilled through from brand new. I ended up adding a few more holes in better locations as well as making the existing holes larger. In hindsight it might not have been the best thing for the plywood floor but then again there are worse things too.
#4 Post by lakerunner » Sat Jul 27, 2019 3:56 pm
I have the aluminum floor so no issue there.
DirtinLa
#5 Post by DirtinLa » Sun Jul 28, 2019 1:16 pm
Thanx everyone for your response.
As I said I am reupholstering the seats. So I’m going to drill drain holes that also align with the screws securing the seat backs so I can go through the hole with the long screwdriver and undo the seat backs and also have drain holes that will do double duty.
-=Fred=-
