I have an 06 SunTracker 21' signature series Party Barge.
The HIN is suppose to be in the rear on the right hand side.
For the life of me I don't see it. Anyone know where it may be hidden?
I have searched the forum prior to asking.
Thanx in advance,
-=Fred=-
SunTracker HIN (Hull Identification Number) assitance
*** MY PET PEEVE *** If you ask for help and help is given be so courteous as to post how you finally fixed the issue.
- FLOUNDERPOUNDER225
Re: SunTracker HIN (Hull Identification Number) assitance
It's there somewhere, look on the engine pod or the aluminum frame that supports the POD, check crossmembers on the right hand side on the stern, would be the farthest one aft. it will either be stamped or a plate riveted to the aluminum.
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
Yamaha F-150
Thank you,
Let me go and look once again... I will report my findings.
-=Fred=-
-=Fred=-
Check the top-right edge of your motor-mount transom.
2015 SouthBay 522FRC w/ F150 Yamaha
1983 Conroy X18 w/ Volvo 125 I/O
Mine is on the frame above the pontoon on the right rear
Thanx y'all I'll report my findings
No time this past weekend but I'll let y'all know. assoon as I do.
Thanx
Thanx
Mine has one the side of the engine pod but you have to be nearly under the boat to see it ( I only noticed it when I was swimming under mine)
