OnBoard Charger
OnBoard Charger
Hey everyone I'm new to this forum. I am a first time boat owner, I've owned my boat for just over 3 years. I have a 26 foot Suntracker Bass Barge powered by a 200 Optimax pro XS. I just looking for some advice or insight. I bought 2 bank XPS iT2 onboard charger and I'm just wondering where everyone else is mounting theirs? maybe some pics? My current setup like most with a fishing pontoon is the trolling motor battery is located in front by the trolling motor and the engine battery is located in the back. The wires are only like 6 ft long so I know I'm most-likely going to need the extenders. It also says in the manual to not mount on vinyl. Anyone have any experience mounting/installing one of these on a boat like this. Thanks in advance.
Re: OnBoard Charger
I don't run a trolling motor but use 2 batteries. 1 for accessories and the other for motor. Mine is mounted in the changing room encloser which is also where my batteries are. I use a timer to only run for an hour a day. this keeps thing charged without worry of overcharging as my last onboard charger did.
Re: OnBoard Charger
I have four batteries on board. Two for the trolling motor under the helmet with a two bank charger right next to them. Port is mounted to my fencing just outside my helmet.
The second two are in the stern with one for the motor and one for the house. Both of these are hooked to the alternator.
I looked into a 4 bank but it was both space and cost prohibitive. If I get around to it I might mount a second 2 bank in the stern.
From the sounds of it your best bet would be to mount in the motor convenient spot close to one battery (bow or stern doesn't matter unless its huge and weight is an issue). Then just tun a single extension under the deck to the second battery.
Pinawa Bay, Manitoba
Re: OnBoard Charger
Thats what I was thinking, just wasn't sure if there was a better way that I was not thinking of.
