Does anyone have, or have seen, a small high performance pontoon?
There are plenty 24’ and up with 150-300+hp. I’m looking for planing performance around 30+mph in an 18’ or less boat.
The boat I have is 16x8, very simple and light (only drivers seat), and runs 18-19mph with 30hp. I have waterskied behind it but it’s more of a stunt than really fun.
I live on a small tight creek, a big newer boat is possible but I’d prefer to keep it small and simple. Currently has two 22” tubes, round with no strakes. I can build or buy/install a center log with lifting features and upgrade to 60-90hp.
Goal is to cruise in low-20s, pull an adult wakeboarder or skier, and pull kids on tubes. And take two families to the sandbar, which I can already do as-is.
I just have no reference as to how this size/configuration of boat would perform.
Any specs to share?
Matt
Small high performance pontoon
Re: Small high performance pontoon
I don't get around much but don't think anyone makes an 18' or less toon rated for over maybe 75hp. Have you looked at something like a Hurricane Fundeck? Even the smallest one is rated for 9 people and 150hp.
What HP is your boat rated for? Technically that could be a limitation.
I am guessing the folks that sell logs would probably be your best technical help as I am sure they do this all the time???
- Liquid Asset
Avalon / Tahoe used to make some small ones. I know you can still get a 18' tritoon with like a 115 powering it. The beam was narrower on the my dealer had a few years ago. It had 6 lifting strakes and a wake board tower. I thought it looked really cool, sure beaia 18' runabout.
Thanks for the lead; google found thisLiquid Asset wrote: ↑Wed Jan 15, 2020 4:56 amAvalon / Tahoe used to make some small ones. I know you can still get a 18' tritoon with like a 115 powering it. The beam was narrower on the my dealer had a few years ago. It had 6 lifting strakes and a wake board tower. I thought it looked really cool, sure beaia 18' runabout.
https://www.avalonpontoons.com/boating- ... t-package/
Which is even a little more performance than I need, probably do OK with a 90.
I'm not concerned with the HP rating; I've rebuilt the transom that is on there, and it may be replaced with an integral center log one anyways.
If you buy a new outboard be prepared to go to multiple dealers that will even sell you an outboard. The first 3 mercury dealers would not sell me a new outboard because it was going on a custom 22ft tritoon. They would not pass the final inspection for warranty purposes because it was not a NMMA certified built boat. On the 4th try I finally found a mercury dealer with an open mind that would sell me a 200hp V6 for my 22ft custom tritoon.
There is a general formula for determining max hp of a hull. (lenght x transom width x 2) - 90. Its only a starting point, but if you have insurance, you can use that forumula to prove you are not over powering your custom boat.
