JB Weld on back of log
mgarvie
#1 Post by mgarvie » Sat Mar 14, 2020 6:15 pm
On an earlier post I mentioned the dog ate the wiring on the back of my log. The wife says the dog stays and I have no where else to park the boat, so I adapt.
Would JB Weld hold 1/2 inch PVC to the back of my log? I figure I could run the wires to the transducer, wash down pump, and LED light strips through PCV pipe if I could attach it somehow.
Ideas?
jediger
Re: JB Weld on back of log
#2 Post by jediger » Sat Mar 14, 2020 8:44 pm
Pinawa Bay, Manitoba
mgarvie
#3 Post by mgarvie » Sun Mar 15, 2020 5:34 am
I had some of that on top of the log around the wires. Found a shredded pile of it in my living room.
Steiner
#4 Post by Steiner » Sun Mar 15, 2020 9:59 am
Is a half dozen t posts and 100' of construction/snow fence out of the question? Would only cost about $60.
#5 Post by bansil » Sun Mar 15, 2020 12:47 pm
Def. Wouldn't use jb weld, 3M 4200 should work for you, clean tube and pvc with scotchbrite and alcohol, small bead on pvc, install and lock in place with tape for 24/36 hrs, then run a small bead top and bottom, using a popsicle stick or cut up CC. Want another 24/36 ond you should be good, 3M 5200 is better BUT it takes a week to cure
