Single 6 gal Portable Gas Tank?
I am thinking about buying a Bass Buggy 16 XL Select. It is my first boat. I just want something to use for a little fishing and to take my bride of 60 years around the lake. At this point in life I don't need to run out of gas. The boat has a Mercury 50 HP and an external plastic 6 gal gas tank.
A long time ago the Jon boat I was in with my wife and daughter had water in the gas I bought at the lake marina and it was a long row back to camp. Don't like the thought of running out gas. Hence, I think it would be prudent to add a 2nd 6 gal tank. My thinking is to just use a switchable Y-connector to hook the tanks together. Does that make sense?
Also, I plan on buying gas at the lake marina. I understand one is suppose to put the tank on the dock for filling. However, I worry about jugging the tank(s) up and down. I would hate to lose my balance and drop the tank in the water. Hence, I plan on filling the tank with it on the boat. The tank will be sitting on a metal plate and should be grounded as will I holding onto the rail. I have done much more dangerous things in my life. Am I being foolish?
Thanks you.
Mike
Thanks you.
Mike
Re: Single 6 gal Portable Gas Tank?
Welcome to the forum. A Y valve will work but add a fuel filter/ water separator. after Y and going to motor
https://www.amazon.com/Fittings-Marine- ... 07&sr=8-14
I use a jiggler pump Or use a quick disconnect fuel line-unhook from one tank and hook up to another. Y valve works great too....
https://www.amazon.com/HORUSDY-Siphon-M ... 158&sr=8-3
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
90 Merc Optimax
Underskinning
28 GPS
Hi Mike, and Welcome!
My 115 HP pontoon boat came with two 6-gallon portables without an interconnect. When one got low, I just switched manually. At a leisurely 14-15 MPH cruising speed, each tank gave me an hour and a half of running, so more than 20 miles. Running wide open, I could drain the 6 gallons in about 35 minutes! Most sunset or sunrise cruises did not require changing tanks, but it was always there.
Eventually, I bought a 12-gallon plastic portable that fit in the same area, just taller, and I kept one of the 6-gallon tanks in place. It was about $100. on Amazon.
https://www.amazon.com/Moeller-12-Gallo ... 92&sr=8-15
I later added a second 12-gallon tank as my grandkids discovered the joy of tubing! I still have not tied them together because I rarely need more than 12-gallons during a trip. (We generally boat within 10-15 miles of our dock) But it's always there and quick-connect fittings make it a 30 second process to change tanks.
Your 50 HP will consume around 5-gallons per hour wide open, and likely 2 to 2.5 GPH while running at a lower RPM/speed. One of my neighbors runs a pontoon boat with a 50 HP and a single 6-gallon tank. He carries a 2-gallon gas can as his "get home insurance" gas.
I fill my 12-gallon tanks onboard while at my own dock, using regular 5-gallon gas cans for the sheer simplicity and ease of handling and storage.
Marc
Marc
Thank you all for your replies. Hopefully a 12 gal tank will fit. It is a long walk from my house to my dock. Don't think I want to juggle gas tanks.
A 12 gallon tank is going to be about 75 pounds. That's a lot of weight to carry down those steps.
You've got a beautiful back yard, but it's a perfect example of why I'll never have a boat on a lake that doesn't have gas at marinas on the lake!
Exactly. I want a large portable tank that I can use as though it is a permanent tank. Zip to the marina, fill it up in place, and go fishing.
Mike
As I said, I fill my 12-gallon tanks on the boat!
