Motor problems???
Motor problems???
Not sure if I posted this in the right place.... I've got a 2011 Mercury it will idle fine but when I put it in gear and throttle up around 3K RPM it starts acting like its starved for fuel.... after a min or so it really chugs and stalls out, and wont start back. I've replaced fuel filters X2, tested both pumps and the float in the fuel mod., new plugs, and new anti-siphon in the tank. Along with new oil and lube in the lower. No beeps other than startup beep.
