1 I have seen a primer for aluminum flooring. Do I need that?
2. there was a tape used by the manufacturer that went around the perimeter and where pedestal seats were. Can I use Double sided vinyl tape?
3. I am using 3m contact glue. I have read that you need to apply to both bottom of the vinyl and the deck. Do I need to apply to the bottom of the vinyl as well as the deck? I
4. Pontoon stuff says to use a 1/16 v trowel for the glue. I have also read that you use a brush or roller to apply the glue. Which do I use?
Thanks again folks.
vinyl on aluminum deck questions
