Pontoon Drain Plugs
zwigstrom
Pontoon Drain Plugs
#1 Post by zwigstrom » Fri Jul 24, 2020 2:14 pm
I have plastic plugs on the back bottom of my logs. I want to take them out and see if there is water in the toons. I am having a hard time getting them out as they strip when I turn them. Can I cut them out and replace with Stainless plugs? I have read where metal plugs react in salt water??? Not sure. Need some advice.
willy13
Re: Pontoon Drain Plugs
#2 Post by willy13 » Sat Jul 25, 2020 3:37 pm
Stick with the plastic plugs. You risk the threads siezing with a metal plug in salt water. The plastic probably got over torqued.
Marc K
#3 Post by Marc K » Sat Jul 25, 2020 3:47 pm
Put some penetrating oil on the threads and let it sit for a few hours before trying. I bet that it won't be a problem.
