I ask because one of my pontoons (2014 Xcursion) is making a large bang sound, when large waves hit the side of it, while riding in the water. It seems like air has escaped and is now hollow or something.
Thanks
Are pontoons generally filled with air or are they empty?
Re: Are pontoons generally filled with air or are they empty?
If by "empty" you mean that the pontoon is a vacuum, they are not. Some manufacturers will pressure test the toons for leaks at a very low pressure (3-5 PSI). Some don't. But it's not enough pressure to add any buoyancy to the boat or add much structural support.
And yes, it's normal for them to sound hollow and empty, because essentially they are!
Every once in a while I hear what sounds like a faint "thunk", but not often and not concerning. I was told, somewhere in this galaxy, that my model Landau (2003) has styrofoam-filled toons. Makes sense because I do ride so very smoothly - in that - I never feel like I'm bouncing across the waves, just gliding through them.
I was also led to understand that this sticker on my toon once confirmed that these toons are styrofoam-filled. Hell I don't know!
- sticker.png (243.17 KiB) Viewed 4496 times
Paul & Michele
2003 Mercury 75hp
2003 Mercury 75hp
Yep, heard that once when my boat was new and I had it out in the Gulf jumping waves. Sounded like a baseball bat to a steel drum. I didn't jump any more waves after that.
no vacuum and no added air pressure, just ambient air in the space.
In actuality, if they could pressurize them, theoretically they would be less buoyant.
Pressurized air is heavier than ambient air. Example, scuba tanks weigh less when empty.
- Capt Sully
My Excursion pontoons are hollow, no air pressure and sometimes make a sound while cruising. It's normal..
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
Could be a loose internal bulkhead.
