Radio beeping
Radio beeping
Hi got a 2012 bentley with an original jensen radio, for some reason the radio has started a beeping coming from the speaker's when the key is on or off, but radio is on ,some say it's the battery but that it good12 plus v v volts anybody have this problem
Re: Radio beeping
I have no idea, but I am wondering if it is telling you that it is waiting for a Bluetooth connection?
Is the radio still "live" with the key off?
Re: Radio beeping
Yes just started a couple of months ago had boat for a year
Re: Radio beeping
Scroll through your menu or settings. There's often a confirmation tone that can be turned on or off so when buttons are pressed you get a beep....first thing I turn off on any new stereo. Maybe if yours has that function something is stuck or shit the bed so it's setting that off.
You might be able to find the model number somewhere on the face plate or be able to see it from the back and find a manual online for it. Example, look at the bottom left of page 6 here..."BEEP TONE"
https://www.rocktheboatmarinestereo.com/specs/MS2A.pdf
