Lift cable protection
rick carpenter
#1 Post by rick carpenter » Thu Sep 17, 2020 8:06 am
The freshwater slip we have our pontoon in is designed for a v-hull so the bare lift cables hit the bimini frame when lifting it. It's not bad, just maybe a little more than contact. Would pipe insulation stand up to the elements and abrasion or is there something more marine friendly?
2021 Sun Tracker 18' Bass Buggy
Boat lives happily on Lake Livingston TX
Steiner
Re: Lift cable protection
#2 Post by Steiner » Thu Sep 17, 2020 10:16 am
Pool noodles?
steve1313
#3 Post by steve1313 » Thu Sep 17, 2020 10:43 am
My lift cables have 1/2" PVC pipe then covered with pipe insulation. Works fine. The tricky part is you'd have to disconnect the end of the lift cables to thread them through the PVC pipe. I also guess you could use some split loom cable covers.
Puto
#4 Post by Puto » Mon Sep 21, 2020 6:38 am
Maybe get some cheap PEX piping (red for hot water would work well) and split it lengthwise. Then "wrap" the lift cables with it. It should stay in place on the bunk itself (gravity) as the lift cable moves through it. Just thinking out loud here...
BobL
#5 Post by BobL » Mon Sep 21, 2020 8:51 am
You could also get some thin gauge PVC pipe then split it with a Dremel tool. Spread it apart and pop it over the cable - it will stay on.
FogHorn
#6 Post by FogHorn » Mon Oct 26, 2020 5:29 pm
^^^^^^^^^ THIS! Also, garden hose can be split and tye-wraps used to keep it.
2015 SouthBay 522FRC w/ F150 Yamaha
1983 Conroy X18 w/ Volvo 125 I/O
Marc K
#7 Post by Marc K » Tue Oct 27, 2020 11:18 am
Good idea.
Flanker
#8 Post by Flanker » Wed Oct 28, 2020 12:47 pm
Get some AC Pipe Insulation. It is already split
Westport KY
Ohio River/McAlpine Pool
2009 Crestliner Bataba Bay
150 Merc
#9 Post by Bamaman » Thu Oct 29, 2020 9:12 am
I agree that 1/2 inch PVC pipe is the way to go on those cables. It's slick and non-abrasive.
