Suzuki DF 90 Trim & Tilt
ezrollin
#1 Post by ezrollin » Fri Nov 06, 2020 1:03 pm
Motor is trimmed to the up or towing position to check fluid level. I can't get motor to go down but can hear pump motor run. According to the manual I can open the manual release valve screw two turns and lower motor manual. It doesn't say I have to move the tilt lock lever, do I have to lift up on the motor to make the lever release?
Re: Suzuki DF 90 Trim & Tilt
#2 Post by bansil » Sat Nov 07, 2020 3:08 pm
Not sure, does the manual switches work on the engine?
Shoot brownsmarine a quick email, great folks and very helpful...hell even same day shipping on 30 year old parts :mrgreen:
ezrollin
#3 Post by ezrollin » Sat Nov 07, 2020 5:59 pm
Got motor up and down by opening hydraulic release screw. T&T motor runs in down position , up relay probably faulty, check it tomorrow, thanks.
#4 Post by bansil » Sun Nov 08, 2020 9:12 am
Fixing to pull out so I can fix trim issue ourselves :nana
