pros & cons of tri-toon?
What are the pros & cons of having a third pontoon? And, because different manufactures are shaping them differently, is the end result different as well?
Thanks
Thanks
Re: pros & cons of tri-toon?
The only con I can think of is price. They seem to be a bit higher than two toons.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
Elm Grove, La
Lake Bistineau
cons are probably large increase in price--need a larger motor usually to get any kind of performance.
Pros are usually better ride and handling and turning etc---prob carry more people too.
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
90 Merc Optimax
Underskinning
28 GPS
I would think that having the toon sitting higher in the water would offset the extra weight and perhaps even give you more speed out of the same motor vs a 2 logger?wwind3 wrote:cons are probably large increase in price--need a larger motor usually to get any kind of performance.
Just thinking out loud here...
That is a good thought also. I had a 2 logger and added a 3rd, same motor and I gained a couple of MPH. Smoother ride, If you TOW it may add a little weight but in the water, it only helps. Cost is the most difference, but then again, think resale...
The only con is price, I can think of. I discovered one pro, I had not thought of by accident last year. I hit a stump and ripped the end cap of the port toon. With the port toon completely inudated with water the boat listed to the left, but kept the rubrail about 4 or 5 inches above the water. also this kept the motor from having any water damage since it never got above the cowl. If it had been a 2 log I am sure it would have went vertical, increasing the damage tremendously. Granted that was a once in a life time event, never thought of anything more than a ding in the log would happen to me, but sure am glad I had the center log on that day. Sold on the tritoon before that happened, but supersold now.
Thats a scary thing to happen, makes me glad my toons also have flotation filler inside... Never can be too safe!dockholiday wrote:The only con is price, I can think of. I discovered one pro, I had not thought of by accident last year. I hit a stump and ripped the end cap of the port toon. With the port toon completely inudated with water the boat listed to the left, but kept the rubrail about 4 or 5 inches above the water. also this kept the motor from having any water damage since it never got above the cowl. If it had been a 2 log I am sure it would have went vertical, increasing the damage tremendously. Granted that was a once in a life time event, never thought of anything more than a ding in the log would happen to me, but sure am glad I had the center log on that day. Sold on the tritoon before that happened, but supersold now.
Yep never even been close to anything like that in 25 years of boating. The stump hit about half way down the toon and when it reached the end it just popped the end cap off like a hubcap. Luckily, I was less than a mile from the ramp and had the trailer there. As I increased the speed most of the water came out an it got back on plane. I didn't know the extent of the damage until I got it back on the trailer. Probably set a record time getting it on the trailer. Looking forward to some warm weather to try it out. Everyone remember to keep your insurance current never can tell when a freak accident like that will hit. It only made a little bump sound like so many other I have heard, so after a little bump you might need to do some checking.mike wrote:Thats a scary thing to happen, makes me glad my toons also have flotation filler inside... Never can be too safe!dockholiday wrote:The only con is price, I can think of. I discovered one pro, I had not thought of by accident last year. I hit a stump and ripped the end cap of the port toon. With the port toon completely inudated with water the boat listed to the left, but kept the rubrail about 4 or 5 inches above the water. also this kept the motor from having any water damage since it never got above the cowl. If it had been a 2 log I am sure it would have went vertical, increasing the damage tremendously. Granted that was a once in a life time event, never thought of anything more than a ding in the log would happen to me, but sure am glad I had the center log on that day. Sold on the tritoon before that happened, but supersold now.
great advice!
holy crap doc, "record time onto the trailer" I would have had the racing stripe in my drawers to prove it!
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
The ones with the motor mount/transom on the end of the center log gives better flotation in the back end.
