AC coil cleaner?
rcl700
AC coil cleaner?
#1 Post by rcl700 » Fri Feb 05, 2010 7:16 pm
Has anyone hear used AC coil cleaner(pink stuff) to clean there toons?
If so any tips on using this stuff?
what products do you use to clean the aluminum pontoons on your boat?
Thanks guys!
1992 Landau Bandit 20' pontoon
2004 Tohatsu 90hp TLDI
24v lenco wireless drive
Re: AC coil cleaner?
#2 Post by lakerunner » Sat Feb 06, 2010 4:49 pm
Works great, be sure and wear long gloves and face protection. I use a gallon pump sprayer and work a 3 or 4 ft area then rinse well. FYI, your logs will look white for a while before the aluminum shine comes back. Also logs will darken faster after using acid.
rcl700
#3 Post by rcl700 » Sat Feb 06, 2010 7:44 pm
do you put anything on after you clean with ac coil cleaner?
do you scrubb this stuff in or just spay and rinse?
where can I find this stuff?
#4 Post by lakerunner » Sat Feb 06, 2010 8:59 pm
No I just rinse well, being sure to rinse trailer well. Go to your local heat & Air supplier. I use Lock Supply. Last I bought was near $15.00 a gallon. Follow mixing instructions 1 Gallon is plenty to do your logs.
You could order some Shark Hide from Clint ( t-birder) a member of this forum and has a great product. Some even go farther and polish the logs to a high luster and then use shark hide
WaltF
#5 Post by WaltF » Sat Feb 06, 2010 11:15 pm
solid advice on the sharkhide! :nana
Colorado Springs, CO.
rcl700
#6 Post by rcl700 » Sun Feb 07, 2010 3:11 pm
Does Clint have a good price on the shark hide product?
How much will be needed?
Thanks for the info. I'll find a heat & air shop to ge the coil cleaner.
#7 Post by lakerunner » Sun Feb 07, 2010 3:43 pm
Here is his website http://www.sharkhide.com/
I think 1 can is plenty
