Ok I raised my motor today. Does this look correct? I went from top hole to bottom hole
I can not test with the 15p prop that I had because I sent it back because of the rpm issue.
I think Im going to try a 13p I just dont know if I should go with a four blade or a three.
test run issues
Re: test run issues
- This was sitting flush.
Is it ok to be like this? - transom view.jpg (101.55 KiB) Viewed 878 times
- motor raise 2.jpg (129.24 KiB) Viewed 885 times
- raise motor.jpg (59.63 KiB) Viewed 878 times
1992 Landau Bandit 20' pontoon
2004 Tohatsu 90hp TLDI
24v lenco wireless drive
