Ttrott... thanks for the heads up... I went back and looked at those covers and the pics they display sure look like the bimini tops are "off". however in thier write up on thier covers, I copied and pasted the following :trott46 wrote:Roland and h2otoo The only problem with the coves on that website is that you Will have to take the bimini off the boat completely also no air circulation when covered most playpens allow the bimini to stay on, trailerable, easy on off, and allow some air circulation.
"You'll need to take into consideration your canopy top - does it stick back off of your railing and extend past your deck in the rear? If so, you'll need to add this to the length of your deck. Basically, you must determine the maximum length of your pontoon boat from front to back, not including the tubes. "
According to that you should be able to leave the bimini top on... if not, I'm not going to fool with it... way too much work there.. as for air circulation I wondered about that and I think you're right. My plan was just to pull the ends up on the cover when parked in storeage to let air pass thru. I've got a playpen cover but it's such a pain to put on, that's why I was considering one of those "other" covers.
