added a trolling motor
ezmuny13
#1 Post by ezmuny13 » Fri Jul 23, 2010 6:47 pm
will post pics tomorrow...due to no front deck extension we had to fabricate a brace which turned out perfect.....installed a pontoon 55 from minnkota.....this bracket it came with is sweet,your able to remove when not in use
texaspontoon
Re: added a trolling motor
#2 Post by texaspontoon » Fri Jul 23, 2010 8:45 pm
When you get the motor going, tell me how it pulls your big toon around. Speed? Is it a 12 or 24 volt system? How long can in run on before it runs your batteries down? Is it a transom mounted or bow mounted on a bracket? (because I have been thinking about adding one but not sure how it would perform.
THanks...
Matt.
ezmuny13
#3 Post by ezmuny13 » Sat Jul 24, 2010 2:19 am
k it's a 12v 55lb thrust w/52" shaft, bow mounted and will update other info...soon as possible
BassFrequency
#4 Post by BassFrequency » Sat Jul 24, 2010 4:55 am
Ive got the same setup on a 24' does pretty good. as for battery life, mine isnt a good comparison guide, yall have seen my battery :biggrin2
60HP Evinrude
ezmuny13
#5 Post by ezmuny13 » Sat Jul 24, 2010 4:49 pm
texaspontoon
#6 Post by texaspontoon » Sat Jul 24, 2010 9:13 pm
Thanks for posting the pictures. Tell me how it moves that big boat around will ya. I am thinking about either going with a trolling motor or a 15hp kicker. (I recently screwed up and put bad gas in my brand new Honda 150. Made it about 1/2 mile from the dock, and went dead in the water. It was embarrasing to be towed back by one of those "SeaDoo" boats, but I was glad for a ride. Even more painfull was the $400 bucks to flush the tank and motor. It is good to have "a little propulsion" in sittuations like that.
ezmuny13
#7 Post by ezmuny13 » Sun Jul 25, 2010 1:43 am
yes,that's the main reason,but second never know when a person might want to rock fish in the fall/winter :biggrin2
#8 Post by HandymanHerb » Sun Jul 25, 2010 6:07 am
Good job, but please tell me you don't have metal touching aluminum,dissimilar metal causes electrolysis and will eat on the aluminum.
So separate them and use SS bolts
ezmuny13
#9 Post by ezmuny13 » Sun Jul 25, 2010 7:46 am
yes i do,and am using ss can i just put a ss washer between them
#10 Post by HandymanHerb » Sun Jul 25, 2010 10:45 am
ezmuny13 wrote:yes i do,and am using ss can i just put a ss washer between them
Yea that should work, either or some rubber sheet, you just don't want them touching each other.
95jagman
#11 Post by 95jagman » Wed Jul 28, 2010 9:00 am
I added the MinnKota 55 lb 52 inch shaft to the front of my 22" Sylvan. I mounted the bracket UNDER the deck so you can't see it and it is out of the way. I also installed a remote on/off switch back at the fishing stations.
2009 Sylvan Signature 8522 F-N-C, RPT tubes, 2010 Suzuki DF150 HP 4 stroke , MinnKota 55 Lb thrust trolling motor, on Lake Hartwell, GA
