What should I look put for? I'm posting pictures of a Toon
Tell it like it is!
ckymacias
Re: What should I look put for? I'm posting pictures of a Toon
#16 Post by ckymacias » Fri Apr 08, 2011 10:06 am
rrhodes wrote:I would not use the rhino underneath. It will actually hold moisture in. Look into underskinning with aluminium this will increase performance and still let the deck breath.
We use a coating like rhino does on our toy hauler ramp doors and it doesn't let moisture in… I get what you’re saying and it currently has aluminum under belly between the toons. But you still don't recommend me coating the decking for extra protection?
ckymacias
#17 Post by ckymacias » Fri Apr 08, 2011 10:07 am
rrhodes wrote:That is good news. Underskinning gives you a smoother ride because the water can't pound the supports and gives you better performance.
Slap some marine grade plywood on there and flooring and you are good to go.
Thanks! Will do and that will save me some more money...! :nana
Is there a standard width that is needed? And do I run 1/2, 5/8 or larger? I didn't get a chance to look last night was to late to dig into that info... I hoping to be able to pick up the decking during my lunch...
Thanks for all the help!
rrhodes
#18 Post by rrhodes » Fri Apr 08, 2011 10:25 am
3/4 inch Marine grade is the norm.
Don't use pressure treated Lowes plywood.
2008 JC Neptoon 25TT
115hp Honda 4-stroke
2007 Suburban LTZ
Lake Murray, SC
ckymacias
#19 Post by ckymacias » Fri Apr 08, 2011 10:31 am
rrhodes wrote:3/4 inch Marine grade is the norm.
Thanks! When disconnecting the steering helm mechanism from the floor will I have to re-bleed the hydraulics after I have disconnect the steering?
ckymacias
#20 Post by ckymacias » Fri Apr 08, 2011 10:48 am
Just found this video on YouTube which I think it will help me with the basics...
http://youtu.be/Hi3RGJgZDfY
ckymacias
#21 Post by ckymacias » Sat Apr 09, 2011 5:36 pm
Wanted to know if I should be worried about this, it smells like 2 stroke oil. The guy purchased it from told me I didn't have to leave the out drive sitting on the flip out bracket.
Leisure Kraft
#22 Post by Leisure Kraft » Wed Jul 20, 2011 12:33 pm
ckymacias wrote:
rrhodes wrote:3 logs gives you a higher HP and weight rating. She will also handle rough chop better. If there is a small soft spot I would bet there are more than one spot. Plan on replacing the deck.
I have seen a lot of people try to add a 3rd log however I have never seen anyone remove one...
Thanks for the info on the tri-toon! I figured I was going to have replace the decking too...
So would I also be able to pull toys with this size model?
The third pontoon makes everything more stable and allows more guests (or a bigger motor on the back). For tubing you're looking more like a 115HP four-stroke or better I think for this size. I believe that's a two-stroke from the picture, it might do fine for you on the smaller tubes. Remember, that third toon also adds resistance and you'll need more motor to get out of the hole.
Michael Blankenship 931-484-2681
Leisure Kraft Pontunes - 1996 Peavine Road, Crossville, TN 38571
http://www.LeisureKraft.com
Find us on the Pontoon Forum members map: http://www.zeemaps.com/295621/Leisure_Kraft_Pontunes
bes2767
#23 Post by bes2767 » Wed Jul 20, 2011 7:20 pm
3 Logs will also virtually eliminate having the front end of the boat get flooded from a strong wave. I had this problem with my twin log tune, even after I skinned it with aluminum, adding tapp fins did help, but the ultimate is the 3rd log. - IMO, White caps or rough water = tri-toon.
2011 Playcraft 2300 w 250hp Verado Pro
Our Live Rivercam: http://www.iowaponds.com/rivercam.htm
