We are owners of a new lake home with (old) boat lift. Want to keep the cables well maintained. Aside from the spray on wd-40 or specific cable sprays...anyone have any good lubricants and application methods they recommend?
ie...ball bearing oil and a paint brush?
Downside of the spray lube is the overspray...either in the water or all over our tritoon.
Thanks for comments.
Boat Lift Cable Lubricant
- Luckycharms
Harris 240 Sunliner
Mercury 200 Pro
Mercury 200 Pro
Re: Boat Lift Cable Lubricant
I was told white lithium grease on cables and rollers by my installer
using cardboard shield and rags i kept the mess to a min
used the spray type
Mike
used the spray type
Mike
2017 Harris Sunliner 200
Tri-toon P+ Package
2017 Mercury 150 4 stroke
Tri-toon P+ Package
I do nothing to lube cables. I can shoot black bearing grease in the bearings, however. Cables last a long, long time on lifts if kept out of the rain/weather.
