A few questions for this boating season (Engine trouble, vinyl repair)
- FLOUNDERPOUNDER225
Re: A few questions for this boating season (Engine trouble, vinyl repair)
GOOD NEWS THERE!
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
Yamaha F-150
- photonfanatic
So I'm thinking spray a little starting fluid in the intake, and see if it will run a few seconds. If so, get rid of all bad gas, and replace those 3 filters someone mentioned. Should be good to go at that point.
I would get the old gas out of the tank (by any means possible) drain the VST and change the filters before attempting to run the engine, just my opinion. by starting the engine prior you are just moving possible contamination downstream towards the injectors. anything will start on "starting fluid" that won't tell you a thing. at a bare minimum, I would drain the VST via the small hose (in the video I sent you) and change the other filters
Pensacola FL
Yamaha F-150
Yamaha F-150
Something you didn't mention, but you may have done this, but did you squeeze the ball on the fuel line to make sure you had the line pressurized? I know it sounds stupid, but I have a 2003 Yamaha 90hp 4-stroke and my fuel line looses pressure after it's been siting for a month or so. But a few squeezes on the ball puts fuel into the motor and it starts right up.
Please tell me you've checked the obvious --> the safety lanyard / kill cord / engine safety cut-out switch (the red thingy in the picture).photonfanatic wrote: ↑Wed May 30, 2018 12:27 pmAs for exactly what the engine is doing, it just sounds like a car that the engine is turning over, but it never will start.
- photonfanatic
If that turns out to be it, maybe I'll just act like it was some big problem that I fixed in a very manly way.
It's worth noting that on surface-mount remotes like that example the safety lanyard comes in 2 different types. One is an electric "kill" switch like the example shown and definitely needs to be present & functional for the engine to fire. But on others the clip surrounds the key and physically rotates it to "off" when the clip is removed, and doesn't need to be in place for the engine to start.
Mark
Rush Lake, Atlanta, MI
I’ve been using Pri-G since before they started putting ethanol in gas.photonfanatic wrote: ↑Thu May 31, 2018 5:33 amWell I was thinking more along the lines of getting the engine going and cleaning it in case there were any of those crystal deposits people mentioned.
I ordered a fuel filter. Guess today I'll check that larger fuel/water separator filter. I'll get the model number and just order a new one. Is there anything else I should check, after I change those? Should I remove the VST (Vapor Separator Tank) and check it over? Maybe check the screen inside? Trying to figure out exactly what all I need to do. And yeah this is my education lol. From now on I'll use PRI-G instead of Stabil. Its supposed to be good for 4 years instead of 1.
It’s damn good stuff!
- photonfanatic
Alright I admit it. It was that kill switch. But in my defense, that part on the key should be at least twice as thick as it is. But that is not really a defense. I only noticed that just now. Still though, it does look like I might have to cut up a washer in order to make it thicker.
Those guys at the dealership were going to charge me $600-$1200!
Kinda reminds me of a newbie 10 years ago that didn't have his throttle in neutral and couldn't get his boat started at the ramp, the very first time he tried to launch it! What a freakin IDIOT! OH WAIT NEVER MIND!
- photonfanatic
Well since we've pretty much got everything else resolved, what about those forward storage things? Are they fairly universal in their shape? And where would be a good place to buy them, since pontoon stuff seems to currently be out of stock or not carrying them.
That can happen. A "friend" of mine was out in his boat, stopped to float while having a beverage and smoking a cigar. As he was finishing his cigar, he noticed he was getting very close to shore. But no matter how hard I, I mean my "friend" tried, the motor wouldn't start. "He" quickly threw the anchor so the motor wouldn't hit the rocky shoreline. After flipping the battery switch, turning the key, removing and reinstering the kill switch lanyard. still no luck. I was about to call for a tow when I realized it wasn't in neutral. All I could do was laugh.curtiscapk wrote: ↑Thu Jun 21, 2018 9:24 amKinda reminds me of a newbie 10 years ago that didn't have his throttle in neutral and couldn't get his boat started at the ramp, the very first time he tried to launch it! What a freakin IDIOT! OH WAIT NEVER MIND!
The only good thing was I was alone on the boat, so I didn't have to endure ridicule from my friends!
- NonHyphenAmerican
Was at the lake one day and a guy had run down his battery trying to start his toon up.
He bought it used from an individual that already had it in the slips.
I loaned him my charger and went out on the lake for a couple of hours.
Come back and he walks down and asks if I'd help him trouble shoot his boat as his is similar to mine.
We disconnect the charger and I go through my personal check list with him.
Motor down.....check.
Throttle in Neutral.......check.
Key in.........check.
Cut off lanyard in place??????? He says "What's that?"
I tell him mine is on a red coiled plastic lanyard and show him where it goes.
"Oh That?" I thought it was just a key lanyard, it's stowed in with the boat junk.
I showed him how to put it in place and told him that quite honestly, I'd never taken mine out and just leave it hanging in place.
I then showed him how to keep the transmission in neutral by pushing in on the center of the throttle and pushing it forward to get a high idle to let it warm up.
Pushed it up about 1/2-2/3rds, hit the key and it started right up.
The guy looked at me like I was a genius.
I told him that when I first got my toon, I'd had to learn things as it was different than my little fishing boat. I suggested he come on here for helpful advice.
He backed out of the slip, and motored out onto the lake, hopefully o have a fun time.
