Tent On Toon
TexasTooner
Tent On Toon
#1 Post by TexasTooner » Tue Feb 19, 2019 6:06 pm
Hi All,
Its been a long time since I've posted - lost my login and took me a while to figure it all out - good to be back. So, here is what I'm thinking.......
As in my signature, I have a 25'Lx 8.5'W Tri-toon and I can't afford the whole camper enclosure. I have read a few posts about using a small tent on the front of the toon, but I want to put a Tent over the whole damn thing.
I found a 25'L by 10'W camping tent that I'm thinking of using. I have double biminis, so my thinking is to cut the floor out of the tent, take the poles out and lay it across both biminis so I wouldn't need the middle pole support, but will at the ends, let the sides hang down, add snaps and then add fiberglass poles where needed to add rigidity.....
Okay - has ANYONE done something like this or am I as crazy as I sound.......
Thanks !!!
Captain StarLord of the vessel Stargazer
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
Re: Tent On Toon
#2 Post by curtiscapk » Wed Feb 20, 2019 7:08 am
Welcome back!!!! Check these out yours should work!
viewtopic.php?f=2&t=25282&p=207394&hilit=tent#p207394
Boat at Truman Lake, MO
TexasTooner
Re: Tent On Toon
#3 Post by TexasTooner » Wed Feb 20, 2019 4:31 pm
Thanks Craig.
Well, looks like I might be a first to try this idea. I’ll post some pics when I get ere’ done !!!
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
r&s20
Re: Tent On Toon
#4 Post by r&s20 » Thu Feb 21, 2019 6:01 pm
i think it would work
but are the sides tall enough that they would hang down far enough ? i think you could make it work if you cut the floor i a big X type pattern, put up and then trim floor to fit
fish and cruise
I am not ADULT SUPERVISION !
TexasTooner
Re: Tent On Toon
#5 Post by TexasTooner » Sat Feb 23, 2019 7:47 am
Ok All,
I done got er’ ordered, meaning the camping tent...... it should be in before too long and I’ll have to open er’ up and study er’ first and devise a plan on how I’m going to do this...... and if it’s feasible before I start doing anything else......
If it does work, which I’m hoping it will..... then we’re off for some new adventures!!!
Keep you all posted
StarLord
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
TexasTooner
Re: Tent On Toon
#6 Post by TexasTooner » Tue Mar 05, 2019 8:35 pm
Ok, the tent is in, but it’s been too cold to setup outside.
My thoughts are to set it up first to see how all the poles setup so I can have a plan on moving it to the pontoon ...... it’s gonna be fun no matter what !!!!
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
