Insalling washdown pump
Looking for help how to install washdown pump
1996 180CC off shore 125 Force [sold]
2000 1801CC Parker 115 yamaha [sold]
2008 2320SL Parker sport cabin 250 yamaha four stroke [sold]
2018 22ft Aurora Manitou 115 E-tec
Re: Insalling washdown pump
I haven’t installed one yet on my toon. But in the research I’d did it’s not very hard. Since I’m in saltwater I was going to install a freshwater tank on the toon. Then get a pump connect the pump to the tank and add a short hose to the pump. I check different sites for pumps west marine has them. I also searched the internet for installing a wash down system on pontoons and found a lot of info on how and what size pumps to use. Hope this helps. There are also some old posts on this topic.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
- FLOUNDERPOUNDER225
I've now done this to 2 Tritoons, mine and a friend's. If you do it right and get a good washdown pump mine is west marine, 5 GPM @ about 40PSI you will be happy with the results, bilge pumps and livewell pumps won't get it, you get a low pressure useless stream of water. you'll need a plastic container, the pump https://www.amazon.com/dp/B00SF58F68/re ... BZ5HHZPL73 here is my set up, works great will shoot a 15 foot stream of water.
- 20151004_115614_resized.jpg (95.34 KiB) Viewed 3357 times
- 20151001_164820_resized_1.jpg (202.93 KiB) Viewed 3357 times
- 20151001_164625_resized.jpg (140.48 KiB) Viewed 3357 times
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
Yamaha F-150
That makes sense! Clean install.
The first time I had seen a wash down was on a charter boat we were on in Lake Superior. I thought what a cool idea!
Not really sure what this guy had for a pump but when you turn it on you could use a spigot to just wash your hands or put out a boat fire with the hose.
Damn that this could shoot far. I kinda wondered if he had gotten that pump off a fire boat or naval ship! LOL
Great idea though. I like your setup. Like someone said before me, " Very neat!"
