Finally mounted
jpmathers
Finally mounted
#1 Post by jpmathers » Sat Apr 13, 2019 3:03 pm
Finally got the mercury 115 mounted, this thing was a hog to get on there compared to the 9.9, Just have to figure out the throttle cables now ,there seems to be a barrel missing or something. Totally different set up then the 9.9.
luckydogs
Re: Finally mounted
#2 Post by luckydogs » Sat Apr 13, 2019 5:56 pm
We mounted our 115, hooking up the throttle cables was EZ, having never done it before we fallowed the installation manual word for word and worked out perfect, if you don’t have the installation manual there’s a couple videos on that subjected on YouTube. it’s a lot easier than you think
Good luck
riplipper
Re: Finally mounted
#3 Post by riplipper » Sun Apr 14, 2019 4:11 am
OK, I just have to ask.....
You are going from a 9.9 to a 115? What size boat? What is it rated for? And how did it come to have just a 9.9 on it in the first place??
Curiosity is killing me on this one.
jpmathers
Re: Finally mounted
#4 Post by jpmathers » Sun Apr 14, 2019 4:46 am
214 Lowe pontoon, The guy I bought it off of lived on a restricted Lake. I've tried finding videos with no luck ,I will look again today.
luckydogs
Re: Finally mounted
#5 Post by luckydogs » Sun Apr 14, 2019 5:19 am
Do you have the installation manual? If not, I can copy my manual on throttle cables
jpmathers
Re: Finally mounted
#6 Post by jpmathers » Sun Apr 14, 2019 5:49 am
I do, It's a different set up on the 9.9. I have to run and get the barrels that slip on the throttle and shifter cable. At least that's all I hope I have to get.
luckydogs
Re: Finally mounted
#7 Post by luckydogs » Sun Apr 14, 2019 6:18 am
Ok hope this helps
jpmathers
Re: Finally mounted
#8 Post by jpmathers » Sun Apr 14, 2019 10:01 am
Thanks
riplipper
Re: Finally mounted
#9 Post by riplipper » Mon Apr 15, 2019 5:07 am
Makes perfect sense now. thanks and good luck with the new engine
jpmathers
Re: Finally mounted
#10 Post by jpmathers » Tue Apr 16, 2019 3:23 pm
Got it all hooked up and running last night. I was planning on taking it to Alum Creek this weekend to see how it does, Typical Ohio weather will probably not let that happen.
luckydogs
Re: Finally mounted
#11 Post by luckydogs » Tue Apr 16, 2019 3:59 pm
And now the fun begins...
