Need DIY railing ideas
Joseph Elliott
#1 Post by Joseph Elliott » Thu Apr 25, 2019 1:30 pm
Well it’s taken me a few years to build my boat but am finally feeling close. Next step is to build a railing. There is no reasonably priced standard pontoon boat square tubing sources near me so I need to make a railing myself. If any of you guys and gals have done the same what materials did you use and any pictures for me? I am currently contemplating using 1” steel water pipe. Thought about electrical conduit but figured that would probably be too flimsy.
Alberta, Canada
Home made 16' pontoon, 1980 60HP Johnson- work in progress
steve1313
Re: Need DIY railing ideas
#2 Post by steve1313 » Thu Apr 25, 2019 2:28 pm
I would think 1" steel pipe would be awfully heavy!
I'm sure there are several online vendors that could ship you aluminum square tubing.
luckydogs
#3 Post by luckydogs » Fri Apr 26, 2019 5:18 pm
Down here they sell a lot of used ones on craigslist (Lakeland Fl craigslist)
Joseph Elliott
#4 Post by Joseph Elliott » Sat Apr 27, 2019 1:39 am
Thanks Steve, I was hoping for a more economical option though. Tubing is expensive up here, it would be $1000 in material alone plus paying for a welder.
Thanks lucky, I will try that and see what I can find.
Alberta, Canada
luckydogs
#5 Post by luckydogs » Sat Apr 27, 2019 1:39 pm
Check this page (link below) some are cheap; I have no idea what shipping would be but that’s just from some of Florida
https://lakeland.craigslist.org/search/ ... byArea=427
mgarvie
#6 Post by mgarvie » Tue Jul 26, 2022 9:24 am
I know this is an older post but I was curious what you came up with.
Kytoon
#7 Post by Kytoon » Thu Jul 28, 2022 5:12 pm
Joseph Elliott
#8 Post by Joseph Elliott » Tue Sep 06, 2022 3:30 pm
Mgarvie, I ended up using 1 1/4" steel angle iron. It works but is heavy.
Alberta, Canada
mgarvie
#9 Post by mgarvie » Mon Sep 12, 2022 8:44 am
I've been considering PVC pipes and netting.
Captain Dan
#10 Post by Captain Dan » Sat Sep 17, 2022 12:44 pm
This some railing I built for my porch, but it would work on anything all materials available at Home Depot. Very inexpensive. See picture. Made from screen cage aluminum and EMT conduit.
mgarvie
#11 Post by mgarvie » Sun Sep 18, 2022 7:29 am
That may be what I need! Framing for a pool enclosure and railing netting like you would get on a sail boat. It would keep the dogs in ,the Asian carp out, and I can see my fishing line and dogs through it. Think I found my winter project.
