What is the fix for a sagging fence door????
JV74
#1 Post by JV74 » Thu May 07, 2020 7:03 am
Hello all. The boat I purchased and am restoring had a new play pen. I just got it installed however the doors are sagging and I wont be able to look at that every day so whats the fix? Should I just shim the hinge? See pic......thanks!!!
toon door.jpg (281.94 KiB) Viewed 3554 times
steve1313
Re: What is the fix for a sagging fence door????
#2 Post by steve1313 » Thu May 07, 2020 7:13 am
Are you sure it's sagging? Maybe it's just the camera angle, but from that picture it looks like the bottom rail is bent and isn't fully parallel to the top rail.
Kytoon
#3 Post by Kytoon » Thu May 07, 2020 8:24 am
Looks like either gate is bent as mentioned by other poster.
Or your top hinge could be loose or warn out allowing it to sag. Is the distance between gate and rail the same on right side top and bottom?
JV74
#4 Post by JV74 » Thu May 07, 2020 8:29 am
It would take an amazing amount of force to bend that bottom rail. I think it’s a hinge issue.....I thought this might be a common thing.
steve1313
#5 Post by steve1313 » Thu May 07, 2020 9:20 am
I think the door was made with a bent rail on the bottom. Take a couple of quick measurements where I've marked with the red lines. If those measurements aren't the same, it's a door problem!!
JV74
#6 Post by JV74 » Thu May 07, 2020 9:42 am
It sure does look bent doesnt it. Good idea I will check those measurements and check for square. I was thinking it was the angle I took the pic from but the more I look at it the bottom does look bent.
guy48065
#7 Post by guy48065 » Fri May 08, 2020 9:06 am
Also put a level against each jamb and make sure they are both plumb--just to make sure it's a *door* issue,
Mark
Rush Lake, Atlanta, MI
JV74
#8 Post by JV74 » Fri May 08, 2020 7:45 pm
I checked the measurements. The door is perfectly square and the bottom rail is not bent. This was all about the angle I took the pic and maybe a shadow. Its just a hinge issue.
Kytoon
#9 Post by Kytoon » Fri May 08, 2020 8:47 pm
so if hinge isn't loose it must be bent like someone sat on it or put a heavy cooler on it. You could try and take hinge off and straighten or replace.
JV74
#10 Post by JV74 » Sat May 09, 2020 6:10 am
Thats the odd thing.....the hinge looks straight as a dime too.....its a mystery
#11 Post by bansil » Sun May 10, 2020 6:26 am
easiest thing would be to swap top and bottom hinge I think
JV74
#12 Post by JV74 » Sun May 10, 2020 7:40 am
Hmmmmm its one very long hinge....but I guess I could still do that.
#13 Post by bansil » Sun May 10, 2020 8:34 am
Mmm...just thinking if top is sprung, bottom may be good and you have a fix, not sure if all hole would line up now tho
