Do you know where I can find something like this
Don't know what it's called or where to look for it.
Anyone know what it's called or where I can buy something similar.
Re: Do you know where I can find something like this
yes for fuel. Thank you. I should have been more specific. I was referring to the shroud.
That old, match hose to a new filler and just make a plate to mount it....chance of 100% mouth is slim to none.
Fiberglass and plastic is fragile and UV kicks its azz
looks like someone installed that backwards ages ago. That trimmed outside edge of the square panel usually went against the mounting surface.
https://www.greatlakesskipper.com/searc ... fill+panel
Here is your closest bets at the moment. I might have a leftover real similar to yours. I'd have to check. I think I tossed them. I had about 6 of these. I custom painted a few and had a couple with clear coat runs and think I tossed them out.
Now that you say that I think your right. It is up side down. I moved into a different direction. More redneck. I have the hose sticking up in the air with a pop up gas lid/vent combo. Going to add more hose so it's out over the back of the boat and if the filler gets a little sloppy or not paying attention the overflow will not fall onto the carpet.
Def. Post pictures of diy redneck fix
- F5E52395-073B-4496-8C93-395D8EE54466.jpeg (1.13 MiB) Viewed 18402 times
