Accessories Links...
Re: Accessories Links...
Bee Ready Rod Holders came highly recommended to me by a ton of friends on http://www.fishingacrosstx.com and I must say they were right! Small, extremely durable, and tough as nails. http://www.beereadys.com/ They make brackets for square tubing on pontoons, but I made my own out of 1/4" aluminium plate and just bought the rod holders.
I bought this bimini top for $129.00. Was a little leary but it is good quality at good price. Does not come with back brace but they are available for around $50.00
http://cgi.ebay.com/ebaymotors/NAVY-BLU ... 6065668731
David & Patty Rose
1990 28' Lowe Classic
90 HP Johnson
2005 Ford F250 Diesel Quad-cab
2008 F150 Quad-cab
2nd home-Woodlawn Shores on TN River
90 HP Johnson
2008 F150 Quad-cab
Dave, did it come with all the attaching hardware ? May buy 2 for the Starcraft. Devising an alternate plan for Canal Days
It did come with everything for mounting including front and back straps and boot.
I got the braces from Overtons.
David & Patty Rose
90 HP Johnson
2008 F150 Quad-cab
90 HP Johnson
2008 F150 Quad-cab
I didn't see this listed here, so I thought I'd share.....
http://www.stickitanchorpins.com/
If you boat anywhere the water is shallow enough, these things work wonders! I got tired of hauling up my danforth with 30 feet of line played out and dealing with mud, muck, sand, etc and liked the power pole anchors but didn't want to put out that much for an anchor. Found these browsing online one day and discovered that a marine supply down the road from where I was staying that week actually carried them in store. I ended up grabbing two of them so I could anchor front and back and they work well. Holds my 4200 lb boat really well.
Later on, I found these and if they weren't so pricey, they would have been cool too (except you'd need a tall ladder or elevator to get on and off from the water) altough you can't really classify them as an anchor, more like a portable boat lift.
http://www.sea-legs.com/
2011 SunTracker Party Barge 22 Regency
2011 Mercury 90hp EFI 4-Stroke
Pea Ridge, FL
Pea Ridge, FL
- CoveDweller
My Pontoon Misting System
Here are a few pictures of the misting system that I recently installed on our 2001 SanPan 2500fe. It took me about 2 hours to complete with most of the time spent running the power wire to the accessory switch. It does a great job and is a big hit with our friends.
- IMG_7095jpg.JPG (873.62 KiB) Viewed 28357 times
- IMG_7062jpg.JPG (817.02 KiB) Viewed 28324 times
- IMG_7067jpg.JPG (983.54 KiB) Viewed 28379 times
- IMG_7080jpg.JPG (930.86 KiB) Viewed 28334 times
- IMG_7072jpg.JPG (571.12 KiB) Viewed 28269 times
2001 SanPan 2500 FE
100 hp Yamaha 4 stroke
Power bimini top,
3-batteries, Misting system, Microwave, Inverter
Bazooka powered sub, polk audio mm651's
Clarion 720 amp, Clarion CMD6
Power bimini top,
If you buy fuel additives in bulk that need accurate measuring, here's a source for double neck dispensing bottles.
2012 Bass Buggy 18
60hp Mercury Bigfoot
Northern VA
Occoquan/Lake Gaston/Lake Anna
Northern VA
- Capt Sully
Wish I had a screen big enough to see your pics.
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
This guy makes stuff for Kayaks that is modular and is targeted for use with ram but makes a bunch of great stuff thats easily removable so there is stuff that will work with the pontoon http://www.yakattack.us/
- chopper6358
1998 Crest 25' Tritoon,115 Johnson 2 stroke. 13x11 4 blade spitfire prop, pulled with 2007 GMC sierra classic 2500hd 4x4. ky lake :nutkick :thumbsup :eviltaunt
I'm going to self-promote if that is okay. I developed a really great upper deck kit for pontoons that is a do it yourself project for anyone to have a double deck on their boat. The frame is all aluminum, and the deck will hold several people. For more information, check out my website: http://www.jsupperdecks.com. Feel free to call me with questions.
Also, just to add fun to our accessory, I'd recommend a slide from here: http://www.aquaglide.com/
Jay Fender
Owner, J's Upper Decks
www.Jsupperdecks.com
We manufacture upper decks custom made for pontoon boats.
I have a turbo swing and love it turboswing.com!
Also, saw these the other day and though they were a fantastic idea!! Lilly pads take up so @#$!@ room on the boat that I never want to take one out with me. The Matt Rack. themattrack.com. Two prices, one with and one without an included Lilly pad.
Hope this helps.
Hope this helps.
This is a 10 year old thread, but still some good info. I have a turboswing, too and also think it's great. The Matt Rack is cool. Wish they had clamps for square pontoon rails instead of round tubes.Puto wrote: ↑Mon Jul 25, 2022 8:32 amI have a turbo swing and love it turboswing.com!
Hope this helps.
